Other spec me a heat gun
Discussion in 'Hardware' started by Otis1337, 23 Jul 2016.
  1. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    finding iv been needing a heat gun more and more and could save a tun of money on repairs on my partners and friends stuff if i had one.
    would a £20 gun be ok?
  2. Vault-Tec
    30 Aug 2015
    I bought a cheap one a couple of years back. Within two weeks the switch went brittle and snapped off. So I had to take it apart, remove the switch and just wire it up so that it comes on at low speed whenever I plug it in. Thankfully I deliberately fitted a plug socket to my desk for when I am working so I can just use the switch on there however beware, cheap usually means cheap.
    If you are going to be using it a lot I would get a decent brand like Bosch. I only use mine for shrinking shrink after soldering and general bending acrylic duties maybe once in a blue moon which is the only reason I haven't replaced it.
  3. Otis1337
    28 Nov 2007
    this is mostly phone/tablet repairs and so on.
    The glass/LCD is a lot of the time is one peace and is glued into the frame of the device where heat guns are needed. You can do it without but there is a high risk of making more damage to the device without a heat gun.
  4. Parge
    16 Jul 2010
    Not the OP I suspected it would be.
  5. Vault-Tec
    30 Aug 2015
    The heat gun I have gets hot after a while. It's because it is made out of very thin hard plastic.
    If you are going to use it professionally (for phone repairs etc) then I would strongly suggest getting a good one.
