Other Spec me a... lawnmower
Discussion in 'General' started by Pete J, 12 Jan 2026.
  1. Pete J
    Pete J Employed scum
    28 Sep 2009
    After many years of reliable service, the budget lawn mower I got free with my house is basically dead and has been taken to the skip. As a result, I'll need a replacement before the gardening season starts.
    Here are the requirements:
    • Corded electric: a battery powered thing won't have the power or runtime for when I need to do the larger plot of land opposite my house, and I don't want the increased maintenance an internal combustion version.
    • A section of my plot has a lot of rocks and stones in, so I want something that can handle being mistreated.
    Here's the one currently catching my eye:
    Bosch AdvancedRotak 650
    RRP is £300, but you can find it for ~£260. However, I'm happy to spend a decent amount more if it means an increase in durability and grass murdering potential.
    Let me know if you have any recommendations. I'm probably going to buy the mower mid March.
  2. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I’ve got a corded flymo in the shed if you are near (Bristol area postcode) been wanting to Facebook marketplace it for £20 or something.
    We swapped to a battery one cos we have a tiny garden now and running power cord jus meant grass got blown inside and was a nightmare with indoor cats anyway.
    By all means still get a fancy one! But this could tide you over?
    b1g-d0g likes this.
  3. Pete J
    28 Sep 2009
    Ohh, let me have a think as I'll be that way 8th February ish.
    I do need something relatively industrial. Any experience with how it handles abuse?
  4. Mr_Mistoffelees
    26 Aug 2014
    Got my silly head on at the moment so, I suggest buy a big ride-on mower and, slap a V8 in it...
  5. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    Einhell....Mines been in the garden getting rained on etc for 3 years and it always goes.... Blade could do with a sharpen though.
    b1g-d0g and Pete J like this.
  6. Mister_Tad
    27 Dec 2002
    What size is the plot of land? I’d posit anything that would be viable to pull a cord across could be handled easily by a large (but admittedly much pricier) battery powered mower.
    I’ve been using and abusing a Makita DLM533 for the last 5 years on a large lawn and only get onto the second bank of batteries when I’ve left it grow well too long.
    And that’s a toy compared to some of the big EGO mowers.
    Pete J likes this.
  7. Zoon
    12 Mar 2001
    I mean it wasn’t an overly expensive one as I recall, like £130, and it’s a hover mower opposed to on wheels. But the old place had a fairly big garden, it was very uneven with lots of potholes and divots, and sloping unevenly away from the house itself. It kept up with twigs, small stones/gravel and weeds where they attacked the edges. It would probably do you as a starter or stopgap by the sounds of it. But you might need something a bit bigger still.
    Pete J likes this.
  8. Spraduke
    Spraduke Lurker
    23 Sep 2009
    I upgraded from a corded flymo to budget battery makita mower and its so much less faff. I do only have a smallish lawn area and it would chew through 2x 3ah batteries but I've now purchased 2x 5ah and that is plenty. I suspect a upper end battery mower with large batteries would have the staying power you need. I have found that the battery mower can 'stall' if the grass is very long or the blade bottoms out but again something with more grunt will probably be fine.
    Pete J likes this.
  9. wyx087
    wyx087 Multimodder
    15 Aug 2007
    I ditched my Flymo for a "Lawnmaster OcuMow" Just drop it on a lawn and it goes around like dumb robo vacuums of old (before smarter Lidar nav ones). Instead of 45min of lawn mowing every 2 weeks, I now use the time to trim the bushes (not a euphemism) whole garden is in nicer shape without spending more time on it.
    I think a newer robot mower that systematically mows and comes back to recharge can comfortably cover quite a large area.
    Pete J likes this.
  10. Pete J
    28 Sep 2009
    Whelp, I've taken the plunge and gone for the larger version, the Bosch AdvancedRotak 750. I looked at a few more reviews, and it looks to be worth the price: I ended up paying £246, RRP is £300.
    I'll get back with my thoughts after I've started using it when things start growing again...
    gamesaregood likes this.
  11. David
    7 Apr 2009
    We had a Bosch rotak mower for 15 years - flawless performance. It's still going, we just don't have lawn that we need to mow anymore, so we gave it away.
    Pete J likes this.
  12. gamesaregood
    gamesaregood Modder
    8 Apr 2004
    I've got a basic Bosch Rotak 32R Electric Rotary Lawnmower that I picked up on an Amazon black Friday deal a few years ago. Does a reasonable job with our average sized lawn.
    Pete J likes this.
  13. Pete J
    28 Sep 2009
    I think that was the model of the one I inherited with the house. Great little mower. Truth be told, I probably should've been more sensible and just bought a straight replacement.
    But new toy...
  14. Pete J
    28 Sep 2009
    Whelp, fired her up for the first time yesterday. Managed to deal with whatever I threw at it - grass, branches, stones, the next door neighbours' cat etc. without hesitating.
    The good:
    • Solid beastie - not going to fall apart anytime soon.
    • Quiet - okay, you're not going to fire it up next to your sleeping child, but it is noticeably more quiet than my previous mower.
    • Heavy - which makes it more manly.
    • Handled wet grass relatively well - I though it was dryer than it was, but hey ho.
    The bad:
    • Heavy - makes it more difficult to move around, even for a fine specimen of manhood like me.
    • Large - I couldn't quite squeeze it into awkward places like I did with my old mower.
    • Harder to push around - this may be related to the sheer "suckability" of the thing, which is why it probably did well with wet grass.
    So, in retrospect, this mower was perhaps a wrong choice for me. However, at least I'm stuck with something that's overspecced and going to last a while rather than the opposite, so hey ho. And the difficulty of moving it around will keep me healthy into my old age. This is more for someone who would normally be considering a petrol powered thing wanting to go electric.
  15. The_Crapman
    5 Dec 2011
    We've got a relatively large lawn, about 15x4m, I have a spear and jackson thing I got for not a lot at all. Has a solid blade, adjustable cutting height, fairly lightweight so easily maneuvered for a crop like me and has been reliable as can be. Could probably do with a new blade after 8 years of chucking stones about the place, but otherwise good as gold
    https://www.argos.co.uk/product/3139301
    I did however splash out on a big boy Bosch strimmer for fun times when it's been left too long and for the weedy wildflower bed.
    https://www.screwfix.com/p/bosch-afs-23-37-950w-230v-corded-brushcutter/8263p
    Pete J likes this.
  16. Zoon
    12 Mar 2001
    In hindsight I should’ve suggested you consider a self propelling lawnmower, then all you gotta do is keep pace with it so your hand is on the cut-out lever :duh::duh::duh:
    Pete J likes this.
  17. Pete J
    28 Sep 2009
    Small update:
    I mowed the larger plot of land I have opposite my house, which is a harder challenge than your typical lawn, what with all the stones and other crap present.. This time, the new mower proved to be very good, better than it's replacement. So, happy days!
    I've ordered a spare blade though....
  18. Zoon
    12 Mar 2001
    Ahh excellent, I’m glad you don’t need to leave a cutting remark about your lawnmower after all!
    Pete J likes this.
