Other Specific C13 (kettle lead) I need
Discussion in 'Hardware' started by MrWillyWonka, 14 Feb 2010.
  1. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    At work we have some new powered wall mounted speakers but on some of the speakers the mains lead does not reach the socket.
    The lead however has a "corner" end which is not right angled nor left but rather a "corner" as the picture shows:
    Anyone know if there is a specific name for this type? I cannot find it anywhere and I need this type in various lengths because straight or right/left angled types will will get in the way of the adjustable speaker bracket.
    Any advice appreciated!
  2. theskirrid
    theskirrid What's a Dremel?
    15 Dec 2009
    You need one of these matey, then make up the leads to suit.
    It's a bottom entry IEC connector [/fnar fnar]
    HTH.
    Krikkit likes this.
  3. MrWillyWonka
    25 Jul 2004
    Definitely, now I know what it's called! A rewirable one should be fine - there is an RS store about 1/2 mile up the road so may pop in to see if they have any in stock although I'm not sure whether they accept casual customers as they normally do trade accounts.
    Thanks!
