Case Mod - In Progress SPEED RACER - Cooler Master Cosmos 2 by Mviana
Discussion in 'Project Logs' started by Mario Viana, 28 Feb 2015.
  1. Mario Viana
    Mario Viana What's a Dremel?
    23 Feb 2015
    I'm Mario Viana, I live in Brazil, I would like to show another work casemod, the theme was SPEED RACER.
    The case chosen and Cooler Master Cosmos 2, The project was developed for Campus Party 2015 CPBR8 run by
    me and my son Rafael 15 years.
    MonitorLG EA93 UltraWide 21: 9 IPS Monitor (2560x1080)
    Cooler Master Cosmos 2 (pearlescent paint with airbrushing and side Plexiglass)
    Motherboard ASUS RAMPAGE X79
    3930K processor
    Power supply Cooler Master V1000
    Video Card: NVIDIA SLI
    Geil 4x4GB DDR3 memory Ran Hot Rod Red EVO VELOCE
    Cooler memory: 2xGeil Cyclone
    Custom Water Cooler:
    12 Fans Cooler Master 120mm Jetflo
    2 fans Enermax 140mm
    1 140mm radiator
    1 radiator 3x120
    Swiftech pump MCP655B
    Top body EK White
    Acrylic tubes hard
    2 VGA water block Koolance
    Block CPU AquaComputer Cuplex Kryos
    Connections Bitspower fittings, EK.
    Liquid Cooler White
    Predominant colors casemod, Pu (polyester) with red and white interior trim in synthetic leather.
  2. Mario Viana
    23 Feb 2015
  3. Mario Viana
    23 Feb 2015
  4. Mario Viana
    23 Feb 2015
  5. SiberianGhost
    SiberianGhost What's a Dremel?
    1 Mar 2015
    The airbrushing is perfect, looks really good. Waiting for more progress
    Subbed!
  6. Mario Viana
    23 Feb 2015
    Inside.
  7. Mario Viana
    23 Feb 2015
    Court of fans 3 1x120
  8. bulldogjeff
    2 Mar 2010
    That is looking really nice, good start
  9. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Thats original. I like it.
  10. Mario Viana
    23 Feb 2015
    Thank you hope to approve the final result.
    :dremel:
    :thumb:
    I'm glad .
  11. Mario Viana
    23 Feb 2015
    Preparing the side to receive the Airbrush .
  12. Teelzebub
    27 Nov 2009
    Nice work looking good mate.
  13. Impeccable Logic
    Impeccable Logic What's a Dremel?
    9 Mar 2015
    Go Speed Racer Go!
  14. Mario Viana
    23 Feb 2015
    Thanks will update the dp possible extent .
    Thanks
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice modding & awesome paint work. :dremel::clap:
  16. Mario Viana
    23 Feb 2015
    Thank U.....
    We are glad that many are enjoying it.:thumb:
  17. Mario Viana
    23 Feb 2015
    Let the side now in acrylic
    Materials and tools used in the process artezanal
    Micro retifica dremel 3000
    Blower thermal
    Lime
    Sandpaper 600, 500 e 360
    Transparent red adhesive wraps of car headlight.
    Bumper reflective bike wheel
    A lot of patience .
    8mm plate
    Applying bike wheel reflective tape
  18. Mario Viana
    23 Feb 2015
    Painting blocks and backplat of video cards
    VGA SLI
    VGA and bridge SLI customized . (Detail: the transparent tube aclilico was painted with vinyl paint .... I liked the result)
    Fitting a straight 80mm fan on the back of the CPU (PCB Motherboard ) gave a very good result in temperature.
    Back Office Party.
    With actual temperature of the CPU socket
    Test fluid , lack the cooler painting memories.
  19. Mario Viana
    23 Feb 2015
    Fans of custom Geil memory in white and red colors ..
    Before.
    After - Fan memory customized
    Customization of the fans of the memory ram
    Result.
  20. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Looking really good. I think Rafael is doing all the work ;)
