Spikes modded AVGS Cool
Discussion in 'Article Discussion' started by CaRRiT, 21 Jan 2002.
  1. CaRRiT
    CaRRiT What's a Dremel?
    5 Jan 2002
    for the tubes in the article it says they r 60mm from maplins but i cant find anything on there that matches it. Are they the 54mm ones? if not do u have the item number.
    CaRRiT
  2. CaRRiT
    5 Jan 2002
    just seen the one with 54mm inner diameter has a cut size of 60mm, i presume these are the ones u used,
    CaRRiT
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    KS87 ... and yes its 54cm .... just about big enuff to duct the two 80 mm fans behind XD
  4. CaRRiT
    5 Jan 2002
    sweet, cheers :)
    CaRRiT
  5. Boggy
    Boggy What's a Dremel?
    3 Jan 2002
    so.
    when is this article gonna be out? i dont mean to be impatient but i relly wanna know more!
    i love that case!
Tags: Add Tags
