Windows Splinter Cell: Chaos Theory I'm stuck on level 2 the ship!
Discussion in 'Gaming' started by Maniac618, 14 Aug 2005.
  1. Maniac618
    Maniac618 What's a Dremel?
    10 Apr 2004
    OK... *rant mode*
    Why og why am I stuck. I've killed the guy and found the 5 crate things and then I go to the back of the ship to get in the emergency getaway ship thing and nothing happens?!?!
    What's going on, have I missed something? :wallbash:
    *rant mode off*
  2. logan
    logan flashback!
    17 Aug 2002
    Check your objectives - primary objectives are*:
    Kill bloke
    Get Bill of lading
    Get Transit Ledger
    Check to see which ones are incomplete.
    Bill of landing is on a crate.
    Transit ledger is on a computer + in filing cabnet (only need to get one - they were in same room iirc)
    *may be worded slightly differently :D
  3. Maniac618
    10 Apr 2004
    I missed the ledger, what button tells me what I need to do?
    Anyway, I'm on Bank now. Thanks.
  4. logan
    logan flashback!
    17 Aug 2002
    On the Xbox version it's "Select" - gives you goals/notes/data/maps
    If you're on th bank one - little tip: you can use your binoculars to remotely access computers. :D
