Hardware Splitting the Atom: Inside the Eee PC 901
Discussion in 'Article Discussion' started by Tim S, 17 Jun 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Timmy_the_tortoise
    Timmy_the_tortoise International Man of Awesome
    28 Feb 2008
    Gotta love Netbook Pr0nz.
  3. evanbraakensiek
    evanbraakensiek What's a Dremel?
    24 Feb 2005
    And still no performance comparisons...! :p
  4. UncertainGod
    UncertainGod Minimodder
    18 Oct 2007
    It's lovely to see what's inside it but we really need to see some performance benchmarks.
  5. samkiller42
    25 Apr 2006
    ooo, shiney, but how much is this bad boy going to cost here in the UK, in Black and with Windows on?
    Sam
  6. Guest-16
    Guest-16 Guest
    Performance is hard because most of the stuff we get uses Linux - until I get an Atom board and organise a VIA C7 EPIA too I dont think it will happen. They aren't designed for performance, just ease of use an inexpensive computing.
  7. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    Yeah, but we're geeks. I'm planning on getting one of these when they're available. Aside from using it for my writing (for which I use Notepad,) I'll try and put DivX videos and NOLF2 on it because... it's just got to be done.
  8. evanbraakensiek
    24 Feb 2005
    Yes, but there must be something (no matter how trivial) to discern between the 900 and 901. I want to know whether the new CPU gives a significant performance increase, beyond the new features like upgraded wireless and added bluetooth.
  9. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    it's a bit silly i think to ask for performance reviews for something like a notebook. it's like asking for a performance review over your mobile phone. it shouldn't really matter because at the end of the day you're mainly running word, the net, emails and basic stuff like that. however, i do grant that we're all enthusiasts here and have a hard on for figures. so go on, performance results please!
  10. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    What ? No Atom closeup shots ? I am shocked :p
    Nice dismantling.
  11. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Not really, if you buy a mobile phone which responds really badly because its either underpowered or the ui is badly designed you'll want to know about since your going to spend a lot of time with it and there is nothing you can do to change it. Hard numbers probably aren't relevant but some subjective comparisons on how "snappy" or other wise it feels would be good especially between the 901 and the 900.
    I'd like a comparison between an atom and an epia but i'm not sure the best way to compare them, but hey that's why they pay you the big bucks bindi :D
  12. Guest-16
    Guest-16 Guest
    ROFL.
    Uh, yea.
  13. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Can you somehow manage to work out what that little button does? It looks intriguing and may be the fabled line-in switch that someone posted about a little while ago.
    edit: I may have to employ you to crawl around on my floor - I have lost a screw from my laptop after taking it apart. It was a bit odd though, I had one spare screw and one spare hole, but they didn't fit into each other :(
  14. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    http://www.phoronix-test-suite.com/
  15. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i demand neked atom die shots!!!!
  16. Solaris
    Solaris What's a Dremel?
    26 Apr 2006
    A review that is both interesting and humorous, great job. :)
  17. UncertainGod
    18 Oct 2007
    El Reg did a very good review of the Linux Edition EEE 901 including some battery comparison info and relative performance info compared to the EEE 900.
  18. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    One of the problems with the original Eee is that it will almost but not quite decode standard-def h.264, which I see as a major use for these things.
    The one I played with - and we played long and hard to get it to work (well, linux...) - will now more or less decode standard def 264 using mplayer with all the "faster and coarser" options turned on, so long as it's been encoded in the right way and there isn't too much motion in the scene.
    P
  19. B3CK
    B3CK Minimodder
    14 Jun 2004
    Spare button, hmm, on some other models, it is used for a couple of things. I work at a Pc & laptop repair shop. I have seen many laptops guts, and often do find hidden buttons on them. They do different things on different Mfgr, models. A couple of them I have found are to clear bios passwords. A couple of them work like cmos jumpers in button format. And one or two that I have found don't do anything at all. I assume they are part of some type mfgr testing. I have even removed one from one laptop mobo to replace a power button for one of our clients.
  20. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    sooo many modding possibilities...
Tags: Add Tags
