Spoiler tags?
Discussion in 'Feedback & Suggestions' started by Guest-16, 17 Jul 2004.
  1. Guest-16
    Guest-16 Guest
    For music and film forum - something like animesuki have encorporated which make the text hidden until you click a button, or makes the colour of the text the same as the forum background. For general use by peeps in series/film threads.
  2. MrDT
    MrDT fapfap
    14 Jun 2002
    You could black out the hidden text, then when you mouseover have the text change colour to make it visible. Anyone who's an sa forum member would know what i mean.
    Useful for talking about 24 series 4 without rtt wanting to beat me with a stick :)
  3. Guest-16
    Guest-16 Guest
    we've resorted to doing grey text atm.
  4. MaxWiz
    MaxWiz What's a Dremel?
    1 Oct 2003
    Might be a problem with coloured text if people are using themes/skins with a non-standard background colour.
    Max
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    i can read that fine :p
  6. Guest-16
    Guest-16 Guest
    surely it doesnt matter in browser because the forum scheme is standard.
    lazy - it makes it less obvious, not impossible so you can easily avoid it.
  7. Lazy
    Lazy Meow?
    13 Nov 2001
    But people can use different themes for the forums. The grey text stands out pretty well on the vb3 forum theme i'm using :/
  8. Ben
    Ben What's a Dremel?
    11 Aug 2003
    unless they use the Vb style
  9. Guest-16
    Guest-16 Guest
    I didnt realise you could select the vb style in here, i thought it was bit style only :eek:
  10. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
    Not sure if it works by default (it doesn't normally) but with a slight modification you could do [color={postcolor}]text[/color] and it will set the foreground text to the same as the background colour of the post, regardless of forum style. Stick a little box round it so people know where it is, and bob's your auntie's brother.
  11. Ben
    11 Aug 2003
    that dose not work unless you make a verbal some were for background as you could do.
    <option style="color:black; background-color: {T_TD_COLOR1}" value="{T_TR_COLOR1}" class="genmed">back ground</option>
    but that puts {COLOR=#******}444{/COLOR} so when you change the style it will not work as it still has the same #******
    if you know php that would help as i do not.
    edit:: gave up
    [COLOR=#b6bdc5)(/COLOR]
    #b6bdc5 is bit background
  12. Hwulex
    1 Feb 2002
    Yeah, but vBulletin uses {firstaltcolor} and {secondaltcolor} and I Think maybe {postcolor} (or similar) in their code, so you jsut have to be able to parse those in the PHP, and you're sorted. IT's very easy to do. :)
  13. davew
    davew What's a Dremel?
    13 Mar 2004
    The Gaming forum needs something done about spoilers too. A couple of times posts have come close to being spoilers about doom 3.
    No worries about anyone reading any text at all in a thread Hwulex has posted in though with that avatar :D
  14. mushky
    mushky gimme snails
    24 Mar 2003
    Can we have something like in this guys sig?
    On that forum, which currently runs on vBulletin 3.0.1, they have a button to insert the neccessary tags alongside the normal formatting tags.
  15. Hwulex
    1 Feb 2002
    PHP:
    <span id="spanShowHide" style="font-family: verdana; font-size: 8pt;">Spoiler: <a href="javascript:showHideSpoiler();" id="linkShowHide">show</a></span>
    div id="divSpoiler" style="border: solid 1px #CCC; padding: 4px;">
    span id="spanSpoiler" style="display: none;">
    $post['message']
    span>
    div>
    script type="text/javascript">
      var
    blnShow false;
      function
    showHideSpoiler() {
    //var chrDisplay = blnShow==false ? 'block' : 'none';
    if (blnShow==false) {
            var
    chrDisplay 'block';
            var
    chrLinkText 'hide';
        } else {
            var
    chrDisplay 'none';
            var
    chrLinkText 'show';
    // end if
    document.getElementById('spanSpoiler').style.display chrDisplay;
    document.getElementById('linkShowHide').innerHTML chrLinkText;
    blnShow = !blnShow;
    // end function
    </script>
    <EDiT>
    Ignore the spaces in the document.get..... line, that's vB working it's magic. :rolleyes:
    Also changed short syntax if to long one so that show/hide text can be changed as well. :)
    Example: here.
