Case Mod - In Progress [Sponsored] Project Metallic Sky
Discussion in 'Project Logs' started by Maple Syrup Mods, 3 Aug 2017.
  1. Maple Syrup Mods
    Maple Syrup Mods Every mod needs a little syrup
    21 May 2017
    Personal Introduction
    Hello Everyone! I'd like to start off by introducing myself. My name is Nathan, better known on Instagram as @MapleSyrupMods and I'm a PC Builder based out of Canada. I've been building PCs for the last 17 years, but only recently started documenting them in the last few. Well I am new to posting here, I am not new to these forums. I have been browsing them for years but never been one to post.​
    Now that that's out of the way, lets get on to why your viewing this thread.
    Build Introduction
    For this build, I have chosen to go with a royal blue/silver collar theme. The idea behind these colours is to create a very clean(ocd, p0pe level), simplistic and high end look. The modifications to the chassis will be very subtle. From this, I have chosen to go with the following parts; But first, I would like to thank the companies that have sponsored me and entrusted to build something that they can be proud to say the represented.​
    Sponsors
    AMD
    Hyper X
    Main Frame Customs​
    Hardware
    Case - Phanteks Enthoo Evolv ATX Glass - Galaxy Silver
    Power Supply - Corsair AX860i
    CPU - AMD Ryzen 1700X
    RAM - 32GB Corsair Vengeance RGB LED DDR4 3000Mhz
    Motherboard - Asus Crosshair Hero VI
    Hard Drive - (2) Hyper X Predator 960GB M.2 drives
    Graphics Card: NVIDIA GeForce GTX 1080Ti
    Watercooling:
    Fittings - Bitspower 12mm in Royal Blue
    Waterblocks - EKWB Crosshair Hero VI X370 Monoblock
    Radiators - EKWB SE 360 & 240
    Pump - Laing D5 with Bitspower Royal Blue MOD kit
    Pump Top - Bitspower
    Reservoir - Bitspower Acrylic 150mm
    Tubing - 12mm copper chrome plated hard tube
    Fluid: Mayhems Pastel Grey​
    Begin:
    The build on the front and back side of the case will look very minimalistic. I have used Hans Peder Sahl(p0Pe) as an inspiration for this build and he has graciously assisted me with some ideas which you may see some resemblance. He is a master of clean looks and a man after my own heart. The cable management is where it will really stand out. I have always enjoyed making custom cables for my builds and have a pet peeve for extra unneeded cable.
    I will forego your typical stock box photos as anyone reading this build thread has already seen what they look like. Let's skip to the pictures where I have assembled them onto the motherboard for validation.
    DSC_0030.jpg DSC_0011.jpg DSC_0025.jpg DSC_0020.jpg DSC_0013.jpg DSC_0006.jpg DSC_0009.jpg DSC_0010.jpg
    AleksandarK likes this.
  2. Maple Syrup Mods
    21 May 2017
    Reserved for final build photos
  3. Maple Syrup Mods
    21 May 2017
    Water Blocks
    Now that the system components were validated and everything working fine, barring a update to the bios to get the RAM to run at correct speeds, I took some time to get the EKWB Monoblock installed. I've always liked the look on the monoblocks and decided that this would help bring some silver back into an already dark board.
    It definitely does not disappoint
    Installation is straight forward, and found everything easy except for screwing it in on the backside. Seem's there is no easy way to install this as you need to hold the block in place, hope that its centred and flip it over. What I did was align the block on the board and put the board on the motherboard box. This allowed me to slide the board 2/3 off the box and insert the screws without risking screwing up the thermal pads and thermal paste. ​
    No longer needed
    With the Monoblock installed, Over the weekend, II will be sleeving the RGB cable for the LED's on the block, as well as installing the water block on the GPU. Here are a couple pictures to show the block installed as well as an idea of where I'm headed with two of the fittings installed.
  4. Maple Syrup Mods
    21 May 2017
    UPDATE: GPU Waterblock Installed
    With home renovations happening, its been really hard for me to be consistent with the build. However, with those nearing an end I was able to get the waterblock installed on the NVIDIA 1080Ti. I'm using the Founders Edition card I ordered directly from NVIDIA. I am using the EKWB 1080Ti FE Block in Plexi along with the backplate in Nickel.
    DSC_0044.jpg DSC_0046.jpg DSC_0049.jpg DSC_0055.jpg DSC_0057.jpg DSC_0058.jpg DSC_0060.jpg DSC_0061.jpg DSC_0063.jpg
  5. warboy
    warboy Insane modder
    24 Nov 2011
    Amazing the choice of color theme. The photos you have made are also beautiful
    Maple Syrup Mods likes this.
  6. Maple Syrup Mods
    21 May 2017
    Thank you!
