Windows Spooler SubSystem App has stoped working
Discussion in 'Tech Support' started by WhiteKnight226, 25 May 2011.
  1. WhiteKnight226
    WhiteKnight226 Minimodder
    2 Mar 2011
    First let me say I did a search and had no luck with it.
    Title is the problem I am having.
    I have an HP dv7-1175nr
    Seen here: http://reviews.cnet.com/laptops/hp-pavilion-dv7-1175nr/4507-3121_7-33360957.html?tag=mncolBtm;rnav
    Ever since I started having this problem, I can no longer print from my laptop. Windows update doesn't fix it. "Check online for a solution" does nothing. I am left at a stand still here and don't know what to do. :wallbash:
    If anyone has any experience with this problem please share some input for me. I thank all who take the time to look.
  2. GoodBytes
    20 Jan 2007
    Uninstall your printer drivers, restart your computer.
    Now, ensure that the service: spooler is up and running.
    If it is, you are ready to reinstall your printer drivers.
  3. WhiteKnight226
    2 Mar 2011
    When I go into Control Panel > Printer, none of them show up. I deleted all of them I could find off of the HDD but some are still on there. I can see them when I open up Microsoft Word and go to select a printer. The error to close the app appears at start up
  4. GoodBytes
    20 Jan 2007
    Ok,
    1- close all programs
    2- stop PC:\Windows\System32\spool\PRINTERS service.
    3- Go to C:\Windows\System32\spool\PRINTERS
    4- Now, delete all files inside PRINTER folder, DO NOT delete the folder, just the folder content.
    5- Start the printer spooler service
    6- restart your computer.
    Everything should be back to normal, like if you never installed a printer.
    If so, install your printer again, and it should work.
  5. WhiteKnight226
    2 Mar 2011
    ok, followed steps 1- 4. 5 I cannot figure out:wallbash:. restarted, plugged in printer, computer made the standard sound of a USB device being plugged in, nothing after that. please advise. sorry for being dumb lol
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    services.msc check print spooler is running, and hasnt been stopped, if its running try restarting
  7. GoodBytes
    20 Jan 2007
    Actually my mistake WhiteKnight226.
    I type to quickly without re-reading myself.
    Here is the correct steps:
    2- stop the Print Spooler service.
    5- Look around Device and Printer panel, to make sure that your printer is not there, unplug your printer USB and turn it off, and uninstall any software that came with your printer.
    6- Use CCleaner,to clean your sytsem and registry, run 2-3 scans on the registry until it doesn't find anything anymore.
    7- Start the Printer Spooler service
    8- restart your computer.
    To Start or Stop a service, it's actually easy:
    Start > type: services > Select the item in the search result Servcies
    It will open a nice panel. On that panel, search for the service, in this case Print Spooler, and double click on it. A new panel will pop-up. You will see a big button called Stop, click on it. To Start it back, simply click on the Start button.
    Hope this is more clear, and hope this works.
  8. WhiteKnight226
    2 Mar 2011
    Thank You
    Ok Goodbytes, I am up and running again. Thank you so much. Printers are now showing up again in Control Panel > Printers and I can print. This being my computer for college, you were a life saver. Much love and rep lol. Hope this doesn't happen again, knock on wood!
  9. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    White...I have that issue at times on a HP deskJet
    HP do a fix it for me desk top application seems to work much in the same way
    Its just easier
  10. WhiteKnight226
    2 Mar 2011
    ya, except my laptop was bought in I think 2008, so no warranty. no warranty means HP doesn't care lol
  11. Blarte
    15 Jul 2008
    my work pc has been a cast off gaming rig bits from several upgrades, the application downloaded from HP still works though
    Error .Printer spooler has stopped .. Clicky HP desktop shortcut .. fix printing problems .. restart printer .. bingo .
    Just go look over HP's web pages I am sure you will find it (incase it occurs again)
  12. WhiteKnight226
    2 Mar 2011
    ahh, good advice. I was referring more towards actually having them help you.
