Modding Spraying Case
Discussion in 'Modding' started by Snood, 4 Mar 2003.
  1. Snood
    Snood What's a Dremel?
    27 Feb 2003
    if i spray my case metalic silver, can i get the same finish on the plastic front? or will it allways look plastic?
  2. Lord_si
    Lord_si What's a Dremel?
    1 Dec 2002
    depends wot kind of paint i think, and how good you are at getting an even finish
    :eyebrow:
    p.s., the smilies on this forum kik bum
  3. Snood
    27 Feb 2003
    i woz thinking of using metalic silver from halfords, but if anyone knows better stuff, pls tell me, and i am good at getting even finishes
  4. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    use some primer first and then spray silver. Make sure to use fine wet'n'dry inbetween coats and let each coat dry for 24 hours before sanding.
    You should be able to get a very good finish on platic, if you have the patience :naughty:
    Meblin
