After some square (low profile) edge trim for my fan holes, MNPTECH have this http://www.mnpctech.com/UChannel.html but im based in the uk. Anyone seen any from UK suppliers? Dont want circle trim please
http://www.cbsonline.co.uk/product/15_x_5.5mm_Rubber_U_Channel_For_1_To_2mm_Panels_TRMU4 Anything with a nicely squared edge only seems to fit panels 2-3mm and upwards, that^ is about as close as you can get really- it's quite thin so should lay flatter when fixed in place, in theory.. Edit: alternatively: http://www.northeasternrubber.com/e...cts/"Small Edge Trim NER2177 (0.5-1.5 Black)" Shame you can't order from the states, McMaster-carr have exactly what you want: http://www.mcmaster.com/#trim-molding/=foux1n ( 1/32" is equal to about 0.75mm )
Emailed one or two companies, will just have to wait and see. Whats the rough Postage time from the US to UK ?
Ok well thats pretty good. Not sure on the added postage price for such a small light item wil literally be 3.4m I think Stil lhoping to find a Uk seller
