Case Mod - In Progress SR-2 STACKER - 'Completed'
Discussion in 'Project Logs' started by coolmiester, 21 Aug 2010.
  1. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    Thank you. :)
    To seperate the tube flows for the different parts (CPU / GFX / RAM & Chipset) your tubing is perfect I think.
    If you don't want to seperate them you can do it that way and you will have less tube in the case I think:
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    its not so much about limiting the tubing, but keeping the components in the correct loop.
    Loop 1 (Purple) i believe is connected to a 120.3 radiator to keep those Xeons cool
    Loop 2 (Red) would be connected to a 120.2 which cools the memory, chipsets and PWR regs
    Loop 3 (Green) of course is another 120.3 for graphics.
    So really he has got the best tubing layout already.
  3. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Yeah, thanks very much for your input Blooddrunken but as Burnout says, i'm trying to keep components separate so at least both CPU's will end up being roughly the same temps which would be better when overclocking.....hopefully :thumb:
    1x 480 rads for CPU's
    1x 480 rads for MB and RAM Blocks
    2x 240 rads for GPU's
    I think that should be plenty :D
  4. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    since the CPUs produce much more heat than the mosfets and RAM, wouldnt it make sense to run your loops more like this:
    loop 1: CPU 1 - mosfet 1 - RAM set 1
    loop 2: CPU 2 - mosfet 2 - RAM set 2
    loop 3: GPUs
    seems like that would more evenly distribute heat among the 3 loops and keep from overloading loop 1.
    sorry if im way off base...im no water cooling expert :hehe:
    EDIT: i think i suggested the same thing as blooddrunken..oops :wallbash:
  5. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    @ Wicket_Sludge
    Yes but rad aren't the same so loop don't have the same cooling capacity.
  6. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    So cool...Don't know what to say, really....
  7. Wicked_Sludge
    15 Aug 2010
    loops 1 and 2 are both using 1x 480 rads.
    loop 3 is the different one, using 2x 240's
  8. BearJew
    BearJew Novice Artificer
    23 Sep 2010
    This is a awesome build. can't wait to see teh finished beast. =p
  9. oliverw92
    oliverw92 What's a Dremel?
    15 May 2009
    I am loving the mini cases, inspires me to do so many things :) Only thing that lets me down is that you are supporting Aquatuning/Phobya.
  10. coolmiester
    31 Dec 2002
    No, no.....you got that the wrong way round oliver, Aquatuning/Phobya are supporting the mod and i thank them for that ;)
  11. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Power?
    How are you going to power this behemoth? Surely you're going to have to use 2 PSU's?
  12. merple
    merple What's a Dremel?
    18 Dec 2007
    I love that baby cosmos you did, but this fetish of yours is getting out of hand.
    Keep up the good work :D
  13. oliverw92
    15 May 2009
    Ok, it is a shame that a company with such bad morals and track record is supporting your mod - someone with such skill and calibre like you can do better than them :)
    Thought about a mini TJ07?
  14. Infiniti
    Infiniti i modded the wheel!
    3 May 2009
    a small nuclear reactor!!! lol
    prob be 2 psus im guessing for stability that and 3 295's take about 600watts alone :eek:
    loving the build specs desperate to get my hands on the sr-2 for my charity folding build
  15. DarkFear
    DarkFear What's a Dremel?
    14 Oct 2003
    I can't help but wonder, how exactly does one just "find" a 1000 watt PSU? :D
    Anyway, awesome stuff! :rock:
  16. DesertFox
    DesertFox What's a Dremel?
    25 Oct 2004
    I wish I could find power supplies. Any hints as to how they disguise themselves? :p
  17. coolmiester
    31 Dec 2002
    LOL, i didn't mean it like that :D - i have a few M1000 PSU's but hadn't realised the difference in the Real Power M1000 which doesn't have the 6pin and 8pin and the Silent Pro M1000 which does and luckily i had one :thumb:
    Anyway, i'm waiting on the EVGA Classified SR-2 1200W PSU to hit Europe but it better hurry up or i might have to have a re-think :miffed:
  18. Infiniti
    3 May 2009
    i love the fact that u can stabalize the overclocks with those dials on the back.... and 12x (6+2) pins is crazy!!!
  19. DarkFear
    14 Oct 2003
    Corsair AX1200?
    Should have mine in the next few weeks hopefully *holds thumbs*
  20. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    That looks like a rebranded Antec Quattro. Must be from the same OEM because they both have the same knobs on the back. Maybe if push comes to shove you could use that instead?
