Motherboards SR-X up for pre order
Discussion in 'Hardware' started by lilgoth89, 21 Apr 2012.
  1. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    not sure if its been already posted
    but scan have the SR-X up for pre order :jawdrop: :jawdrop: :jawdrop:
    i want one :waah:
    http://www.scan.co.uk/products/evga...dr3-4-way-sli-plus-crossfirex-sata3-usb3-hptx
    cant wait to see some of the mods people come up with for this ( although they would likely have to sell a kidney and the first born child to afford it + the xeons :thumb: )
    at £563 it dont come cheap ( although thats pocket change to what the xeons will come to :lol: )
  2. longweight
    7 May 2011
    I was hoping for it to look a bit more interesting!
  3. Guest-23315
    Guest-23315 Guest
    They really should just call it the /e-peen++ already..
  4. KidMod-Southpaw
    28 Sep 2010
  5. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I'm amazed they've even bothered to use air cooling. They should just supply waterblocks for the price.
  6. KidMod-Southpaw
    28 Sep 2010
    Depends one one's use really, there's obviously still going to be people who just want to get an air cooled workstation set up. Waterblocks would probably add another ~£100 considering their size.
  7. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Heh, I've been tempted to go dual socket for a long time. I'll have to check on these back when I go home for the Summer. They're about 40% more expensive in the UK so no thanks :)
    A pair of E5-2687W's would be amazing. But the motherboard and two CPU's alone will be around $2700. Ouch.
  8. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    This confuses me, they've put it in the dual 1366 motherboards category, but its socket 2011?
  9. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    I'm a bit disappointed that such a high-end board only has 2 SATA III ports.
    The_Crapman likes this.
  10. .//TuNdRa
    12 Feb 2011
    Only two sata. Aye, but also two sas, which are crazy with enough sas expansion cables. Think 8 drives per port.
  11. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    if I ever got one of these I would max it out. Fill every single PCIe slot with graphics cards even if I can't get more than 4x SLI I'll still do it. Run as many displays as I possibly can, u3011's off my main cards and probably u2412m's off the extra cards. 20 SSD's, 18 in RAID0 and 2 in RAID1 as boot(18 per SAS connector, 1 per sata3 port), 4 hard drives(for the lonely SATA2 ports). 96gb of DDR3 1600 of course(btw, Scan lists it as having DDR2 memory :eyebrow:). Jesus, I'd need a hell of a case to put it in. Any suggestions?
  12. rollo
    rollo Modder
    16 May 2008
    you wouldnt use Sata at all on such a board
    workstations sas drivers and cable link 4-8 drivers per port
    £563 for a motherboard is some nuts pricing
    mind you 2 xeons will be 4x that so maybe not
  13. Mac_Trekkie
    10 Sep 2011
    It's a hell of a lot of motherboard, so it's a hell of a lot of money!
  14. .//TuNdRa
    12 Feb 2011
    Hell. Get enough Sas Expanders and you can theoretically have well over 20,000 devices per port. That's how crazy the standard is. So 'Only' having two of them on the board isn't actually that large an issue, it just saves on space.
  15. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Trust you lot to teach me something! I didn't know sas ports could take so money drives.
    Learn something new every day!
  16. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    4 drives per port, 8 total. Those are SFF-8087 mini SAS ports.
  17. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    I disagree, every expander bottlenecks bandwidth that much more... if you want a 1GBps or faster array, you really can't use expanders.
  18. .//TuNdRa
    12 Feb 2011
    I never claimed speeds would remain good, I just said you could have a crazy number of devices per port.
  19. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
  20. JohnSheridan
    JohnSheridan What's a Dremel?
    30 Dec 2010
    Looked at that board for a dual-Xeon setup but has quite a few disadvantages so struggling to see where it fits in the marketplace :confused:
    Xeon can't be overclocked (or only very very slightly)
    The board is HPTX so you need a suitable case it will fit in - Xigmatek Elysium is one that would work.
    Only 2 sata 6gb/s ports
    Over-priced when looking at other dual-Xeon mobos already out there
    For me I'd rather go with the Asus Z9PE as that has 6 sata 6gb/s ports and is over £100 cheaper.
