Case Mod - In Progress SR2 Build
Discussion in 'Project Logs' started by B NEGATIVE, 2 May 2012.
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    New tops pre modding....
  2. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Thats a sexy looking pump top! Very nice of Specialtech to help you with your build!
  3. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
    Damn this is looking sweet, I need to get me some of them fans! Keep up the good work man ;-)
    Sent from my GT-I9100 using Tapatalk 2
  4. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Your pictures are screaming at me. Rude.
  5. B NEGATIVE
    8 Aug 2011
    A bit more work done on the front panel...im debating as to putting another LED strip in the top so the light fades down also..
  6. B NEGATIVE
    8 Aug 2011
    Doing as bit of stress testing today...
    No more than 40c on the hottest GPU core.....
  7. Jeti
    Jeti What's a Dremel?
    9 Sep 2012
    Hells teeth. Looking grand. Very nicely done
  8. Sarakon
    Sarakon The German
    11 Feb 2011
    The front panel looks excellent!
  9. ziza
    ziza What's a Dremel?
    21 Dec 2010
    The watercolling and cable management looks perfect.
    The front panel with the illumination fits perfectly in the final build.
  10. B NEGATIVE
    8 Aug 2011
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking excellent :):rock:
    Some nice ones there, I'd be split between yours & mass effect 3, not signing up though because they are cacist against air cooled fools lol. :D
  12. B NEGATIVE
    8 Aug 2011
    I dont understand how a build with no GPU,just a block and a rad can get 15 votes...or even be eligible....
    Anyway...
    Its my birthday and i gots a new camera.....if only i knew how to use it......
  13. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    :idea:that front panel is too..what should I say..umm.. traditional?
    Grab some touch screen bro, tranditional knob is not fit in your rig..
    just my opponion... :thumb:
  14. Squigly
    Squigly MODfiend.. ~twitch~
    20 May 2012
    I still drool over this build!! Just epicness in every direction!! Really hope my pipes work out somewhere near as clean as yours!!
  15. B NEGATIVE
    8 Aug 2011
    I am with you there,i want an aquaero but im not sure it can handle 2 d5s and 15 fans...
    Maybe the new Corsair link kit can....
    A little case shot before do the finish up shots tomorrow
    The finish line is in sight!
  16. Primum Agmen
    Primum Agmen What's a Dremel?
    21 Sep 2012
    I have to say, the pipe approach over tubing really does make it look so much better. The front panel does look a little... orange rather than red though. Tend to agree on the touchscreen fan controller, too.
  17. jay2
    3 Oct 2012
    In that case, you should make a custom fan controller then..
    But yes, knob style potensiometer is easier to make (buy), using arduino to control that many fans maybe will generate too much heat at arduino board.
    You have so many fans bro :rock: (literally :D)
  18. karlpox
    karlpox What's a Dremel?
    18 Sep 2012
    @___@ so sexy :) :)
  19. Sarakon
    Sarakon The German
    11 Feb 2011
    That looks freaking cool!! :D :thumbs:
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    New cam :clap: looking good & a late happy birthday for Wednesday too. :D
