Case Mod - In Progress SR2 Build
Discussion in 'Project Logs' started by B NEGATIVE, 2 May 2012.
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    The best of Multiplay i47
    Sharing stand space with Coolmiester was great,class builds and mine didnt look too much out of place...
    Got good feed back on my build,which was really good and encouraging!
  2. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Is there any buildlog on the blue/white CosmosII build ?
    All the builds looked just stunning :D!
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Was that a LAN compo B?, congrats. :D:clap:
    Crazy beast rigs. :D
  4. B NEGATIVE
    8 Aug 2011
    Coolmiester had the 2 Cosmos there and as this one was sponsored by XSPC,he asked if i wanted to display it with his rigs on the XSPC stand.
    You can see where I got my love of 2CPU rigs........:D
  5. B NEGATIVE
    8 Aug 2011
  6. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    i can hear the dinos roaring out of the case now! :thumb:
  7. B NEGATIVE
    8 Aug 2011
    Working on the OC now..
    Stock GPU's,OC'd X5650s
    Still got a lot more in the tank too.....
    6th place for now....
  8. B NEGATIVE
    8 Aug 2011
  9. Si_the-dude
    Si_the-dude Techaholics Anonymous. 0 days clean
    17 Dec 2012
    An incredible, insane build mate, congratulations. If money was no object I’d like to have a go at something like this and would DEFINITELY use the LD-V8 range. Sadly, money isn’t no object. LOL!
  10. B NEGATIVE
    8 Aug 2011
    Bit of a never ending one this build,evolution Cheesecake
    So the Aquaero plan starts to come together....
    Thanks Specialtech for this bit of kit!
    Slowly getting all the bits i need to start modding this case properly.
  11. siliconfanatic
    10 Sep 2012
    God i wish i could afford that... mobo is cheap but the processors are what kill your wallet..... course budget just makes it a challenge! :D
  12. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Got the very same Aquaero model, only with the waterblock installed. I hope it's as good as I plan for it to be.
  13. B NEGATIVE
    8 Aug 2011
    The waterblock is key to performance apparently,that little heatsink is worthless
  14. Jeti
    Jeti What's a Dremel?
    9 Sep 2012
    Still jealous of it.
  15. B NEGATIVE
    8 Aug 2011
    Dont be,this board can be hormonal sometimes,owning a SR-2 isnt all plain sailing.
    And Tri Sli is a PITA.....
    :thumb:
    On the plus side,she is a brute and looks great in there!
    :D
    Hopefully the screen is coming next week so ,once Arctic Water is finished, I can crack on with this.
  16. jinq-sea
    15 Oct 2012
    Nice. Can't wait to see the updates...!
  17. B NEGATIVE
    8 Aug 2011
    More goodies have arrived but this is all im showing you till the rest of it arrives....
    Magoo approves this post.
  18. B NEGATIVE
    8 Aug 2011
    TO THE PRON!!
    A nice stack of Aquacomputer lovelyness
    Some Alphacool BP clone pass thru's....damn sight cheaper!
    If you want your Aquaero to run multiple fans then this is a must,Aquaero Waterblock.
    Tidy machining as you expect.
    Aqualis res,pump mount version.
    Pump top to match...D5 version.
    I did say i was going dual loop right?
    Those pump rings are going red for sure!
    So....I have my 12/10 E22 ultraclear but im waiting for c47's to tidy it all up and im swapping out the blocks for MIPS Iceforce CPU blocks.
    Im running a lot of the tube under the midplate and using pass-thrus,im bending all the mobo tubing tho,expect a detailed method and plans for the jigs and formers that i will be using shortly.
  19. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    Dem goodies :I
  20. Nutman
    21 Oct 2008
