Case Mod - In Progress SR2 Build
Discussion in 'Project Logs' started by B NEGATIVE, 2 May 2012.
  1. Karrek
    Karrek Minimodder
    7 Jun 2011
    Fantastic
    excellent job so far - I love the clean look and the colors. great attention to detail as well! :rock:
  2. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Yay!! My polishing torch has arrived!!
    ........should of known really.
    Im fluent in IKEA so lack of instructions is not a problem.
    Interesting to note that the gas is switchable with no dead man safety...
    Acrylic polish 101 soon!
  3. Ilias78
    Ilias78 What's a Dremel?
    23 Jul 2012
    Subscribed! Absolutely fantastic work you are doing there mate! :)
  4. Att1cus
    Att1cus What's a Dremel?
    3 Aug 2012
    Yo dude - could really use some advice on those metal tubes. What material and size are they? which tube bender did you use? Most importantly, how did you get them to seal well with the fittings on the CPU blocks and such? Was it difficult to measure?
  5. Att1cus
    3 Aug 2012
    Not sure why my post didn't show, but I have to ask more about the tubes. What size and material are the tubes? what fittings are you using for them (I can't find much for 'push fittings')?
  6. B NEGATIVE
    8 Aug 2011
    After speaking to Ricardo from ColdZero, i managed to get this done.
    a nice little sli bridge cover!!
    http://www.coldzero.eu/
    They do a remarkable amount of plexi modding bits and are well worth a look for one off pieces,backplates,front panels.....the list goes on!!
    Rapid turnaround and great customer service,i recommend you take a look.
    Nutman likes this.
  7. Att1cus
    3 Aug 2012
    Any chance you can recommend/link the fittings you use for 1/2" 5/8"OD metal pipes? I'm new to the metal pipe thing and prepared to lose a few nights sleep getting bending right, but i hope to save myself some headaches with fittings.
    If you can link the push and the compression fittings that work best with metal tubing it'd really help me out :)
  8. B NEGATIVE
    8 Aug 2011
    Koolance may do a 1/2" fitting, i am only aware of 12mm and 10mm fittings.
    You can get 12mm tube in the US (seeing as you asked for 1/2",im assuming you are US?)
  9. Att1cus
    3 Aug 2012
    Yep - thanks for the reply! I bet you get a ton of questions on here.
    I am from the US and have used 1/2" ID 5/8" OD in the past, as I have heard that allows for maximum flow. Is working with a smaller diameter tube a viable concern?
  10. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    That's nice B-Negative!
    -AverageNinja (also from the OC3D Forum).
  11. B NEGATIVE
    8 Aug 2011
    I get a few. :thumb:
    The difference between ID's for flow is slight,nothing to worry about.
  12. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Thanks for pointing me towards coldzero.eu - some really nice stuff there. +1 rep!
  13. Dhemon
    Dhemon What's a Dremel?
    8 May 2012
    Well, very well. Follow you ;)
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice sli bridge :) how has the polishing torch been doing for you? I wouldn't mind trying a faster route for polishing acrylic :D tried a blow torch with minimal success but a specific built one for flame polishing is more like what I need I think.
  15. B NEGATIVE
    8 Aug 2011
    The torch works a treat,its not a polish specific thing tho... It takes some practice,get stuck in fella.
    Look what came in the post...one short tho.
    Oh so sexy.....
    Nowhere near the same amount of mill marks as EK....
    The plating is very good!!
    The wrong way up for my purposes...
    So,out come the allen keys...
    .......orly?
    I have a method for these tricky o-rings.
    Get the o-ring in the groove at one end.
    Slide the block piece over the end you just placed,after pulling the bolts out of course. You dont want to snag the o-ring and damage it.
    then bolt it down...simples.
  16. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    I love those waterblocks!
  17. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Can you explain for the hard-of-modding like me why you've switched the inlet/outlet port around?
    Many thanks in advance
  18. B NEGATIVE
    8 Aug 2011
    My case is a BTX or inverted layout,when the blocks are installed the lettering would be upside down.
    And that would bug me.
  19. B NEGATIVE
    8 Aug 2011
    oops double post
  20. B NEGATIVE
    8 Aug 2011
    Not really build related but i gots me a new monitor!
    Achieva Shimian 1440p 27" IPS.........for £200!
    I have one stuck pixel on the far right of the screen but its well out of the way and is soooo tiny that it only shows on black screens.
    The colour tho,is something else,very vivid....makes DayZ look awesome!!
