Windows SSD Not detected by installation Disc
Discussion in 'Tech Support' started by DeafGamer2015, 1 Mar 2014.
  1. narwen
    narwen narwen
    6 Aug 2010
    "only requires" is the same as "minimum requirements"
  2. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    Ok, It got detected when I connected it VIA USB in Gparted so I'm thinking that the sata data cable is borked. it only works when it want to work..
  3. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Do you have any spare SATA cables? I'm down the post office later to post some RAM out for Shirty so I can bung you a few in the post.
    EDIT: your in bloody Canada!
  4. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    I did the same thing the other day myself, I figured that by the time postage had been covered, it would be cheaper to get one from Canada.
    Sent from my GT-I9505 using Tapatalk
  5. DeafGamer2015
    5 Jun 2010
    Yeah I didn't even expect that Edit comment so made me laugh..
    And No I don't have any spare SATA cables.
    I agree.. I can get one here anyway.. they're cheap for Sata Cables
  6. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    How can you have no SATA cables? :D I've got hundreds of the damn things. And usually when I need one not one of them has the right config of ends on. :D :D
  7. DeafGamer2015
    5 Jun 2010
    That's the thing, I only have laptops.. this is my first tower in years!
  8. DeafGamer2015
    5 Jun 2010
    Ok, replaced the sata cable.. still not detected.. is it possibly the power cable??
  9. Cerberus90
    23 Apr 2009
    At this point I'd probably be thinking that it was a compatibility issue between SSD and motherboard/SATA controller.
    I've got a bit lost and confused with what you've done and what the SSD works in. Can you sum up the situation of what works and what doesn't?
  10. DeafGamer2015
    5 Jun 2010
    Possibly what you said.. but it was detected VIA USB so something must be up with the sata controller...
    Sata is enabled in BIOS so it must be an issue with the controller. I can't seem to update the BIOS without windows.. Hmm...
    One second, I'll try and find the sata drivers.. Why you no easy to read, Lenovo!
    Can't seem to find the sata controller drivers but if I recall, one of posts said try the chipset one but it's an exe file..
    http://www.driverscape.com/manufacturers/lenovo/laptops-desktops/7387a34/32496
    Will this work?
  11. DeafGamer2015
    5 Jun 2010
    FINALLY!!! Thanks to TGS and his generous donation, my 2nd SSD got detected!!! Thank you everyone! :clap::clap:
    Fook you Kingston, making it harder for me to use your SSD brand and all..
    Thank you Sandisk! :)
