Storage SSD various errors - Can't format it
Discussion in 'Hardware' started by r1sKas, 12 Aug 2014.
  1. r1sKas
    r1sKas Orange or White? Lets mod!
    22 Jan 2011
    Hello guys, i have here one SSD that was in a office, and they did a remake in the office, so they gave away some parts, including this SSD.
    A few problems found while trying to format / instaling windows or Unbutu.
    - Error 0x80300024 ( this one appeared when i tried to instal windows)
    - Error:16014 ( this one appears when i boot the SSD), shows this error then a DELL home with Login
    - error input/output error during write on /dev/sda ( this appeared when i tried to instal unbutu or when i try to erase the data in SSD).
    Also, i tried Hirens CB BOOT, and same error, also, tried Parted Magic and i can't create new partions, same error ( error input/output error during write on /dev/sda).
    BTW: in Parted Magic shows good health life and passed the tests.
    I think i used all my ideas, and i dont know what to do now... btw i'm on a laptop.
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Have you tired to do ata secure erase on it? You can do it with the parted magic. This should set it back to factory state. If that dosen't resolve it then the only thing you can really do with it is to pursue any warranty it might have.
  3. jinq-sea
    15 Oct 2012
    Assuming these are the SSDs that were found in the bin, I wonder if they are encrypted.
  4. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Errr maybe that's why they were binned? Anyway, see if the drives can be flashed with a newer firmware and maybe try a samung utility. If the drive was here with me I would try using EaseUS Partition master Server edition. If that cannot format or kill a partition then nothing can.
  5. r1sKas
    22 Jan 2011
    There is some pics:
    You find anything wrong?
  6. r1sKas
    22 Jan 2011
    You can close this.
  7. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
    Figure it out? or did you ask the question, "Will it blend?!"
    pete* likes this.
