News SSDs do increase battery life
Discussion in 'Article Discussion' started by CardJoe, 16 Jul 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. wyx087
    15 Aug 2007
    so less than an hour of extra laptop battery time for how much more premium you have to pay?
    the question now is: is it worth it? (don't forget the tiny space)
  3. Joeymac
    Joeymac What's a Dremel?
    3 Oct 2006
    "Is it worth it?"
    Well depends on your circumstances. If your only machine is the laptop and it sits plugged in on a desk most of the time ....and you keep all your music and movies on it. Then the storage is probably more important. If however it's a smaller, more portable laptop; and it's a second machine. Then the storage won't matter as much and you can spend the cash if you want to have faster booting and a more snappy OS etc.
  4. wyx087
    15 Aug 2007
    how about the Ultra-portable class, EEE 901 vs a similar priced HDD with similar spec
  5. p3n
    p3n What's a Dremel?
    31 Jan 2002
    SSDs are pretty cheap (and similar in size to other laptopdrives) now...
  6. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    I'll be intrested when I can get a 120GB SSD at a good price
  7. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Once they reach 400-500GB then I'll sit up and pay attention, until then...meh!
  8. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    theres more to it than battery life, SSDs are nearly indestructible compared to a traditional hard drive which is especially important in a mobile device like a laptop
    they'll also outperform a traditional laptop disk
    most laptops also come with relatively small disks anyway, so the capacity difference isnt as big a deal as it is on the desktop
    although i do think people are kinda missing the point of SSDs when they whine about not being able to get 500gig ones
  9. naokaji
    naokaji whatever
    8 Dec 2006
    dont forget that ssd's are far faster than the crappy low rpm drives you usually find in laptops, dont look at the numbers several raptors on a areca put out, the ssd's also produce almost no heat, have no moving parts and weight less on top of the lower power consumption... really pretty much an allway round win except for capacity and price, but how much storage do you need on the go? just have some extra storage at home and only carry the data you actually need and the size isnt an issue leaving the price as the only downside.
    seriously, what hdd manufacturer paid TH for the original article? make the step to the future and try ssd..
  10. 1ad7
    1ad7 What's a Dremel?
    13 Feb 2008
    well its not worth it to most people just like Sli and crossfire, but it can add to your epenis and if your a business man or woman who flies alot this could really help you, an hour is usually long enough to get to an outlet.
  11. TreeDude
    TreeDude What's a Dremel?
    12 May 2007
    The 64GB OCZ is over $1,000. The 32GB is $450. These things are damn pricey.
  12. Veles
    Veles DUR HUR
    18 Nov 2005
    Yes, because regular HDDs are slow as hell, even high speed ones.
  13. kingdavies
    kingdavies Minimodder
    29 Aug 2004
    ROFL where are you shoping? The 64GB costs £184
  14. sleepyhollow
    sleepyhollow What's a Dremel?
    4 Jul 2008
    Quite frankly i dont give a dam. In two months times my new laptop will support dual HDD's. Windows will be on a 64 CB SDD and all my progs n games will be on a 7200 HDD. Now if that dont cut it im off to a gimps party dungon where mistress whips me all day long ha ha
  15. FvD
    FvD What's a Dremel?
    12 Oct 2002
    Actually OCZ SSDs come in two versions: "OCZ SATA II 2.5" SSD" (expensive ones, bout 750EUR per 64GB) and "OCZ Core Series SATA II 2.5" SSD" (cheapos for bout 190EUR per 64GB)
    On a sidenote: are SSDs actually measured in GiB or rip-off GB?
    Manufactureres should realy l2- binaryprefix or should be forced to :D
  16. Furymouse
    Furymouse Like connect 4 in dagger terms
    4 Feb 2004
    What about the limited amount of writes/rewrites? Thats whats putting me off( especially seeing as my sd card just died with all my pics on it )
Tags: Add Tags
