Graphics Stability Question
Discussion in 'Hardware' started by Strudul, 7 Feb 2011.
  1. Strudul
    Strudul ~
    31 May 2010
    I did have my GTX 460 on quite a high overclock, but I now want to set it to a lower, more stable setting, but still with a nice overclock.
    I use these settings on furmark. (xtreme burning + post fx on), and my overclocked graphics card doesn't last long. It gets up to 84C after a few mins and then crashes.
    However, I can run the Unigine Heaven benchmark and/or 3D Mark 11 multiple times without any trouble.
    How "stable" does my graphics card need to be to be counted as "stable" ?
    Thanks
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Start playing the most demanding game you normally play - if it runs fine for a couple of hours you have yourself a stable overclock. If it doesn't, well then you turn it down.
  3. Strudul
    Strudul ~
    31 May 2010
    Well. In that case my MSI N460GTX Cyclone 1Gb is stable at:
    Volts - 1087
    Core - 905
    Shader - 1810
    Memory - 2100
    At those clocks I have never had a problem in any game or benchmark, and I can run furmark (with xtreme burning on, but with post fx off) for 10 mins.
  4. adam_bagpuss
    24 Apr 2009
    10mins !
    thats hardly a test at all
    run it for how ever long you game for and slightly longer.
    i.e. the longest you game is 6 hours in any 1 session so test for 6-7 hours and it will be perfectly stable.
  5. Strudul
    Strudul ~
    31 May 2010
    My card lasts in games (crysis at max settings), but furmark just makes it hot really fast :S
  6. Picarro
    9 Jun 2009
    Furmark is supposed to make it hot. Real games will never be as demanding as actual benchtests. (Except for the poorly coded Crysis and Arma II which is utter nutter.)
  7. Strudul
    Strudul ~
    31 May 2010
    I have run crysis for about 6 hours straight at max settings and never got as hot as furmark after 5 mins :/
  8. Strudul
    Strudul ~
    31 May 2010
    When people use furmark, what settings are recommended for checking stability.
    Im assuming you use highest res, fullscreen, highest MSAA samples.
    But im not sure about Xtreme Burning mode and Post FX.
    With Post FX off, my card temperature levels off around 72, but with it on it increases very quickly to 84 and as i said, crashes.
  9. Parge
    16 Jul 2010
    To be honest, stable in Furmark is a good indication of a stable OC, but its not a realistic representation of games so if its stable for you in BC2 or whatever you play, its stable.
