Case Mod - In Progress Star Wars Mod: First Custom Loop
Discussion in 'Project Logs' started by birdie, 9 Sep 2018.
  1. birdie
    birdie Member
    5 May 2003
    I know what you mean, but yeah I would really like to make a scene :)
    I also don’t have crazy hardware and no RGBness on the mobo or RAM, so I think if don’t do a theme it will look pretty boring...
  2. birdie
    birdie Member
    5 May 2003
    Decided to continue with the Star Wars theme. Quickly knocked up a model in Fusion360 for the new front panel. Then printed it quickly in draft mode to check measurements (so ignore the stringing) and see how it will work. I had to print it in two halves as both my print beds are 200x200 and this model is 200mm wise so too close to the edge.
    4DE486A4-43EF-4832-8AE0-E4994280D522.jpeg 9ED7E278-82C7-41C1-8961-EC1EB2AA6AC8.jpeg
  3. birdie
    birdie Member
    5 May 2003
    Now I need to work out the mounting method and also decide if I keep the stock power/reset/USB bit and model a bit that meets up with my new front or if I just model an entirely new bit.
