Modding stargate keyboard mod...how do i do it?
Discussion in 'Modding' started by JavaBoy, 22 Jan 2006.
  1. JavaBoy
    JavaBoy What's a Dremel?
    21 Oct 2004
  2. Deathrow
    Deathrow Minimodder
    30 Jul 2005
    Dissasemble, spray keys black, use white tip-x pen to draw the symbols.
    Do they make white sharpie pens?
  3. JavaBoy
    21 Oct 2004
    ok first off, could anyone recomend a good keyboard for this mod?
    2nd what kind of shapies/markers are the best
    3rd do i have to be an artist?
  4. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    It will probably look a little messy if you just draw them on. You could try printing them off and then making stencils.
  5. JavaBoy
    21 Oct 2004
    how do i make stencils?
    and what kind of materials to i need? what kind are sharpies, keyboard, paint, ect...?
  6. the_fox
    the_fox What's a Dremel?
    27 Dec 2003
    use white decals ;)
  7. Hegemon
    Hegemon What's a Dremel?
    4 Jan 2006
    You might try printing the symbols on cardstock or some other thick paper. Spread the symbols out across 1 or even 2 piecies of paper and print them the size you want them to be on the keys. Use an exacto knife to cut out the letters, and now you have a stencil. A coat of white spraypaint should do it, maybe a shot of clearcoat over the whole key later on.
  8. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    exactly what hegemon says, save for the fact that keys usually have a concave curve and a stencil might over spray (former stenciler) anyways I would do the exact same, but on sticker paper which can be bought at office supply stores, it would give you nice contact with the keys and woudln't run through.
  9. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    As to a keyboard i would suggest something like the saitek pc games keyboard.
  10. obzelite
    obzelite What's a Dremel?
    9 Jun 2005
    something like this?
    Had a mishap with beer and keyboard on the weekend, so figured I would have a play.
    Tried to fill it with black paint to get some definition, but didn’t give enough time to dry before wiping off excess, still the residue now shows up the engraving plus how rough the surface is as the paint gets in every scuff. Wet and dry before paining would be a requirement.
    I’d build in an allowance of two keyboards to die for parts for this mod as well.
  11. JavaBoy
    21 Oct 2004
    ok i think i have a plan, im going to use sticker paper and cut the symbols with an exacto nife.
    i will have to start next weekend when i am off. will regular spray paint work? will it chip?
  12. Isotopian
    Isotopian What's a Dremel?
    19 Oct 2004
    It may not chip so much as just wear off over time- keys get a lot of play after all (especially the R, N, P, and O keys).
    If you go with spray paint you at LEAST want to put a clear laquer over top for protection.
  13. Fatboy
    Fatboy Bored
    8 Oct 2001
    How did you do that , its excellent.
  14. obzelite
    9 Jun 2005
    engraving machine.
  15. AJB2K3
    12 Dec 2005
    @ obzelite wow thats good.
    @ Javaboy go engraved not stickers, the stickers will come off easy.
  16. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Ooh... nice idea!! Engrave the keys, spray them black, fill the engravings with UV active paint and put a UV bar above it :D
  17. obzelite
    9 Jun 2005
    now we are going somewhere, just the filling of the keys is going to be a job for someone with a 1 hair paintbrush and a whole lot of patience
  18. ReFredzRate
    2 Sep 2002
    *cough*ask your gf*cough*
    I think women are better suited for that job than men.
  19. HowY
    HowY What's a Dremel?
    14 Feb 2005
    We used to fill dice embossing with PASTOIL
    or an oil pastel crayon. Rub wipe clean let
    stand a day and done. Worked really well
    and you could likely find reactive crayon.
    The wax will harden up so there is no smearing
    really cool idea with the embossing of the keys!
    I'd just find some dry transfer material and
    rub down the symbology - lines and circles
    are available for electrical symbols and alpha
    characters. Much less work to strip the letter
    and make up new keys with some rub down
    transfer and clear it.... jus a thought....
  20. Hellboy787
    Hellboy787 What's a Dremel?
    3 Nov 2005
    HI Guys,
    I have done a keyboard modd, and a very good one If i says so myself, I cant take any photos as yet (digicam is being repaired).
    I used a MS-Wireless Optical keyboard, which I sanded down, including all the keys 'cos the letters were raised, I then sprayed them silver & blue and painted bottom inside part of the keyboard with blue glow in the dark paint. For me the best part was the blue font which I designed with Photoshop 7. I then I printed the font on special-transparent-water-transfer-paper, called "SUPER-CAL" & "Last Step", look it up the stuff is magic.
    So my suggestions to you would be to chose your font or design first, and once you have it, then start to mod your keyboard.
    Let me know if you want anymore advise or info.
