Stargate Themed Mod
Discussion in 'Modding' started by Mother-Goose, 19 Dec 2005.
What gate should i have on my case?
  1. Atlantis
    17 vote(s)
    21.3%
  2. SG1 - (the original)
    63 vote(s)
    78.8%
  1. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    yeh i was trying to work out how id get it spinning, i like your idea, although im not all tha sure how the metal sturcture....works (cant find the right words today).
    actually i dont know how u intend to build it at all, im tryin to think of a way u can explain it to me....hmmms
    i think id use a toggle switch to make it spin, is there a way i could get it to spin one way then the other or something?
    just so u know, my metal/wood/electronic working skills are non existant so it has to be explained simply (it can be hard to make, im not worried about that)
  2. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Plasticard, minimotor (10mm dia), big plastic cog.
    Double pole, double throw togle swithc also known as a changeover switch.
  3. Mother-Goose
    22 Jul 2004
    from what i can see there are two types of plasticard, could u find a link to a site so i know which sort you are reffering too?
    as for the spinning both ways i meant it could do a cycle of them, one way then another then back again, just like the gate dialing up, but id only have to press the button once.hmmmms
  4. isho
    isho What's a Dremel?
    10 Jun 2004
    Hey mother gooser, how goes it with this mod?
  5. Nezuji
    Nezuji What's a Dremel?
    23 Oct 2004
    TOTALLY off the top of my head, never actually done anything like this, but for the event horizon effect, using a whole LCD monitor seems a bit like overkill to me.
    What if you made a 2cm sandwich of (from outside to inside):
    Plexi (outer window)
    Car mirror tint film
    Overhead transparency (with "wave" shapes printed white/clear on black)
    "Wave" shaped "honeycomb" structure with white/blue LEDs inside each cell.
    Depends on how hard you wanna go with this and how good you think it would look, but I reckon you could rig up a circuit with a microcontroller to cycle through the lights in a fading pattern to make something that would look kinda like (dodgy mock-up artwork ahead):
    Just throwing the idea out there for consideration...
    Nezuji :)
  6. MrMacomouto
    MrMacomouto What's a Dremel?
    28 Mar 2004
    Original, atlantis sucked ass...
  7. khendar
    khendar What's a Dremel?
    25 May 2004
    For the ripple effect - have a look at the way disco light gobos work:
    http://www.premier-lighting.com/sales/animate.htm
    There are ones which produce a perfect water ripples like effect. Set up a miniature projector and use a mirror setup of some kind to project it onto the event horizon...
  8. parag0n
    parag0n What's a Dremel?
    15 Mar 2006
    I was considering doing a mod similar to this, but making a model of the SGC gate, with ramp and MALP, and putting an ITX board and webcam inside the MALP :)
    Then i remebered i ahve a low budget and hardly any time, so i went back to my first project ;)
  9. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    So, did this mod ever start?
