Cooling Started fitting watercooling today
Discussion in 'Hardware' started by babychaos, 25 Aug 2002.
  1. babychaos
    babychaos What's a Dremel?
    12 Apr 2002
    I started on the water-cooling project on my case today...won't be finished until late next week as I'm waiting on a waterblock, but here are some pictures to date...
    This is the front res mounting...a Black Ice Prime sits just behind this fan...I'll be doing the filing on the plastic tomorrow, as my file seems to have done a wander and I need to get a new one...
    This is the res mounting in the back...the small "tube" res fits into the slot here, and velcro straps go across it from the 4 mounting holes seen either side. This was the real dremel killer of the day, due to awkward angles...
    Tomorrow I'll be making the pump holder from the old 3.5 rack (the HDD is now sitting in a caddy in the lowest 5.25 bay)...the pump is an Ehiem 1250, and doing the filing to neaten everything up...hopefully then once the CPU waterblock has arrived I can strap it all together, test it overnight and then install it all :D. I'll sort out some internal pictures once theres stuff inside worth seeing (as opposed to sitting in a box doing nothing).
    I'd like to say thanks to everyone on these forums for giving me the confidence to try this...of course if it all goes pair-shaped I'll be here whining like a 4-year old... ;)
  2. Haddy
    Haddy World Domination
    22 Jan 2002
    sounds like a plan....to bad pics dont work.....
  3. babychaos
    12 Apr 2002
  4. Haddy
    22 Jan 2002
    they work now....they didnt work when i first saw it....
    ewwww green leds =P makin bloooooe
  5. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Lookin good :D
    Looks like that front intake could do with a little filing :)
