Build Advice Starting a new budget build
Discussion in 'Hardware' started by TheZaak, 2 Sep 2013.
  1. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Yeah I can't agree with that enough tbh. It's really annoying when you build a rig and the CPU starts holding things back and there's bugger all you can do about it :(
    Always sensible to buy a decent unlocked CPU. That way you can get a year down the line and overclock it when you need to.
    I'll never buy another locked CPU as long as I live. They're not even disposable prices.
  2. teppic
    teppic What's a Dremel?
    18 Jul 2011
    Here's it's the board rather than the CPU :) The cheaper 970s allow overclocking but the VRMs will overheat and throttle, and the poorer phase design will give up.
  3. AlienwareAndy
    7 Dec 2009
    My Extreme 3 is 4+1 but I still managed a 4.2ghz overclock Prime stable with my 8320.
    Any more and yes, the VRMs throttle the CPU. I would imagine you could easily get 4.5ghz out of the 6300 on 4+1? it's got two cores missing.
    As much as the VRM throttle annoys me I do like it. I had an Asrock board once and I fried it by overclocking a 140w Phenom 9950.
  4. teppic
    18 Jul 2011
    People get very good results with the Asus EVO (it's 6+2, but very high quality). 4.5GHz on an 8320 on that board isn't unusual.
    If you put a small active fan over your VRMs you might get rid of the throttling and get up higher.
  5. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    Scan are doing the 580GTX with their warranty and returns for 113 quid.
    ( Which after much debate with the folks bought for my second PC - given how much aof a bargain it was [ because of strict budget ] )
