Modding Startrek case
Discussion in 'Modding' started by AJB2K3, 30 May 2007.
  1. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    I have an idea for a startrek case but apart from borg cubes what other startrek theme cases are there?
  2. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Just pick a race and use there architecture. I like cardasian styles like in DS9. Its all pretty organic.
  3. saltynay
    saltynay What's a Dremel?
    12 May 2007
    theres a few Klingon case I have seen, borgs are quite popular do you want to make it in the actual shape of a starship of just like a part that you might find in there ship? not very pratical but you could make one shaped like voyager and place the motherboard and slotloading optical drive in the disk at the top. If you want some inspiration on what possible look through the project logs here or www.mini-itx.com which has some crazy ones like the waffle iron mod :D
  4. AJB2K3
    12 Dec 2005
    Ive got two idea's ATm USS Defiant (got deck plans from an old book or a Kligon bird of pray but i just wanted to see if there were more then borg cubes for cases and google not giving me any hits.
  5. saltynay
    12 May 2007
    quite hard to get any detail on the hull sounds like a difficult mod do you have access to a vacuum forming machine??? you could make the mould vacuum form it and the cover it in fibre glass for strength
  6. jediknight0
    jediknight0 What's a Dremel?
    7 Aug 2003
    I'm working on an Enterprise NX-01 mod here.
    More updates this weekend, almost done...
    NOTE: you might want to fix the title of this thread (typo).
  7. AJB2K3
    12 Dec 2005
    Opps just noticed it.
    Ill be keeping an eye on it.
  8. Big_Adam
    Big_Adam What's a Dremel?
    6 Jan 2004
    Mate Garry of mine is building the original enterprise and is planning to stick a pc into it. Complet with all the lights for the engine and a stand with a little TV as a plaque displaying the star trek logo but then rolls over to play video and what have you.
  9. Geocide
    Geocide What's a Dremel?
    1 Jun 2007
    I'd like to see a borg sphere, just for the none-cubeness of it
  10. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Deep Space Nine with the motherbord in the center. That would have to be huge.
  11. AJB2K3
    12 Dec 2005
    Probubly nearly 2 meter across using standered mother boards.
  12. jediknight0
    7 Aug 2003
    I finished my Star Trek mod (Enterprise NX-01 themed case) this weeked (see post above). I still need to take some real pictures of the case (probably will have to wait for next weekend).
    Not to thread-jack, put this thread could use a little color...
  13. Emon
    Emon What's a Dremel?
    14 Jun 2004
    No offense to jediknight0, but nacelles sticking out of the top of the case is not exactly what I call cool.
    You're better off theming your case after the architecture seen in a particular series. Think of it this way: If you do a TNG theme, it should look like a prop that would fit well with other props on a set.
  14. AJB2K3
    12 Dec 2005
    This is what i was thinking
    The rear section would be detachable to hide the conections
    but of corse im far from even looking at starting this.
  15. saltynay
    12 May 2007
    have a slot loading optical drive in the front
  16. AJB2K3
    12 Dec 2005
    Ah yes a much better idea, thanks id forgotten about slot load.
  17. saltynay
    12 May 2007
    get a commell lv-676 or lv-677 can't remember which but one of them supports desktop cores so you can put a quad core in that puppy
  18. AJB2K3
    12 Dec 2005
    May use my EPIA M10K if I try it.
  19. saltynay
    12 May 2007
    little boring lol won't be that quick if you wanted to make it really small then you could use a pico-itx motherboard and then 2x2.5" hdd drives onboard layed outwards through the wings and maybe an internal wireless so that you can store all your files on a home file server extremely easy just cram as many hdd's into an old case as possible and you won't have an issue
