Peripherals Static electricity and aluminum keyboards
Discussion in 'Tech Support' started by silk186, 25 Nov 2024.
  1. silk186
    silk186 Derp
    1 Dec 2014
    Fairly often I will get a shock when sitting down and touching my keyboard, it will cause my screen to go black for a second. This is obviously not ideal. They keyboard is plugged into a USB hub which is connected to my laptop. Any ideas how to fix this issue?
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Do you get shocks touching anything else grounded?
  3. silk186
    silk186 Derp
    1 Dec 2014
    water filter on the kitchen sink
  4. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Do you also get same monitor behaviour if touching metal bits on the laptop? (eg, USB port)
    I bet the issue is with laptop. The screen going blank is what we want to solve isn't it?
    Not sure how to solve it though, perhaps touch a radiator when sitting down?
  5. Spraduke
    Spraduke Lurker
    23 Sep 2009
    The static is almost certainly caused by wearing man made fibres or walking on nylon carpets so the "fix" is to wear natural fibres. The workaround is to touch something metal that is grounded (like a radiator) before sitting down to discharge yourself.
    The black screen is probably induced by the high voltage (but low current) "jump" of static to ground that can emit all sorts of radio frequency interference and upset electronics.
    wyx087 likes this.
  6. silk186
    silk186 Derp
    1 Dec 2014
    I can't be sure, it doesn't happen every time, but does happen around once a day.
    Is there any way to mitigate this? I assume it will also happen when I build my new desktop?
  7. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Easiest solution I can think of is to touch your computer case (assuming metal) before anything else as that will be grounded. Whether that causes your screen to flicker still I cannot say.
  8. Bloody_Pete
    11 Aug 2008
    In my experience, its wearing synthetic jumpers. Its the action of your arms against your body that usually does it. I don't wear jumpers for that reason! If you're worried about it for build, get something like this. At work I just tap the grounding before i work on anything and that serves me well. If its anything really sensitive, I wear the strap, but no PC parts are that sensitive these days!
  9. Mr_Mistoffelees
    26 Aug 2014
    I use a wrist strap with a crocodile clip on the end of the wire, which is holding an earth pin, just plugged into a nearby mains socket. 6000V+, even at a very small current, can very easily burn holes in complex ICs. I worked in electronics manufacturing for a number of years, the need for ESD prevention was drummed-in often.
    These days it may be over cautious but, over caution is better than, "oh sh!t..."
  10. Gareth Halfacree
    4 Dec 2007
    (Man, I love that show.)
  11. Bloody_Pete
    11 Aug 2008
    Honestly, the protections systems in modern consumer electronics are so good, its basically impossible! In the video linked above, I think they do 12Kv and its fine. I do a lot of high end embedded systems and they can go either way, either they're OTT, or there's nothing and I'm designing it! And I'm not putting ESD protection on GPIO lines! :p
  12. Mr_Mistoffelees
    26 Aug 2014
    I feel I should point out, that I was working in electronics around 25 to 30 years ago…
    The older you get, the more out of date your knowledge becomes, if you don’t update it.:grin:
    IanW, adidan and Bloody_Pete like this.
  13. Bloody_Pete
    11 Aug 2008
    The stuff I'm playing with would boggle your mind! :p And you'd probably be massively envious about the software which does so much for me now :p
  14. BazzUK
    BazzUK Are we there yet?
    6 May 2024
    Humidity is also a cause of static
    Used to happen at work a lot until we got better air handlers
