It's been a while but I knocked this one up for a M8 [GiB] Soul fly as a one off, perhaps? I wanted to try and make it look less tarty then the chrome LEDS and ali switches. I think it looks DARK The LEDS are bright Blue and a Red power one. It goes in a black Globalwin case. The switches were a little troublesome and I had to use a whole saw. But nothing I couldn't handle :dude: Some more images going up on the site, soooooooooooon.
Looks great. I like it better than the typical ones you see. Only thing I would change, would be knobs instead of swithces. I like things to be variable.
very nice... i may do one, except all my fans are tailed in the 3pin plug. is it possible to get the 3 pin sockets?
Just a simple on/off design for now that was requested by Souly. I will however be expanding into combo's soon as I need it for a project I'm working on. Thanks for the thanks The simple things can be the best solution..........................
ya you can get 3 pin female molex's ... i just dont know where .... a couple of my fans came with em ... a passthru cable with a 3pin socket and a male and female 4 pin molex ... if anyone knows where to pick these up lemme know .. i need more ...
