Case Mod - In Progress Stealth Curves by Mpovh - Final Design - 8/1
Discussion in 'Project Logs' started by Mpovh, 5 Jan 2008.
  1. Mpovh
    Mpovh Minimodder
    8 Nov 2007
    Hello guys, I started a new project of casemod, Stealth Curves is the name, the project will be done in mdf, with retro theme, giving the value of curves and straight in the casemod, will be used the colors silver and apple red.
    Clearing the workshop:
    My Dog :p
    Finished:
    adapting the case:
    Making the front panel
    OUCH :waah:
    Testing:
    First Stealth Piece
    Mounted:
  2. Mpovh
    Mpovh Minimodder
    8 Nov 2007
    Creating the second stealth piece
    Adapting the chassis
    Front Panel
    Mounted
    Side panels
    other
    Top panel
    testing
    Mounted
    url="http://imageshack.us"][​IMG][/url]
    Creating the interior
  3. Mpovh
    Mpovh Minimodder
    8 Nov 2007
    Ajusting the interior
    Creating the other fan suport
    The interior piece
    New solution for Front screwa
    finished
    mounted:
    Then I put more atualizations,
    And Sorry me for bad English
  4. fungry
    fungry What's a Dremel?
    14 May 2006
    Those sidepanels are pretty appealing. By the way, what did you use to attach two pieces of wood. Are those screws and nuts or are they rivets?
  5. Mpovh
    Mpovh Minimodder
    8 Nov 2007
    In chassis I use rivets, in mdf pieces I use the screws and nuts xD
  6. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    i like your mdf work. whats going to go in that gaping hole at the top?
  7. Cigano
    Cigano \O/
    5 Jan 2008
    Much Mpovh you with worklog here also, my English is so bad that I have to translate many things hehehe! I will follow you here tabem. Direct from Campo Grande MS Brazil !!!
  8. FrooP
    FrooP can I eat this?
    24 Oct 2007
    dude this looks way to awesome for your shaky hands, get a tripod :)
  9. Mpovh
    Mpovh Minimodder
    8 Nov 2007
    500mph I will make some details at the top, and this hole will be something like a top window =P
    Cigano Heeey Ciganeta \o/ auhauhauhauahah Campo Grande is a super potency in Casemod World asuhasuhasuashuashuhs ok ok Not so much aushuashsa... \o/
    FrooP I am take pictures with my pda, why I do not use a tripod ;P
  10. Mpovh
    Mpovh Minimodder
    8 Nov 2007
    New pieces to my Case:
    1 Cold Cathode Akasa Azul com Inversor R$ 36,00 ( Blue CC)
    1 Cold Cathode Akasa Verde com Inversor R$ 36,00 (Green CC)
    2 Fan 80mm Akasa 4 Leds Azuis Sleeve Bearing R$ 23,80 ( BLUE Led FANS)
    1 Fan 120mm Cooler Master Azul UV SILENT R$ 25,90 ( BLUE UV)
    1 Chapa de Acrílico Cristal 33 x 37cm R$ 29,99 ( ACRILIC SHAPE)
    1 Mini Conector 2 Vias - 05 unidades R$ 2,00
    1 Cabo Y - 3 Pinos R$ 2,50 ( Y CABLE)
    1 Extensão para Fans - 3 Pinos R$ 2,50
    :thumb:
  11. Mpovh
    Mpovh Minimodder
    8 Nov 2007
    Hey Guys, Im was finished the design of the case.
    first Design ( october -2007)
    Final Design
  12. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Good god, that thing is gonna weigh a TON! Lookin' good though, keep it up... :thumb:
  13. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Very nice start, that is one heck of a large chasis to start with, what is that 1m tall?
    What color do you plan to paint the MDF board?
