Modding Steam bending plywood
Discussion in 'Modding' started by Hugo.B, 11 Jul 2007.
  1. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    I am progressing on with my second case, and have met a problem which could be resolved by bending plywood.
    Has anyone here done it before, and if so, do you have any advice?
    Thank you.
    H.B.
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    plywood is cheap, give it a shot and let us know how it goes. it could be really cool.
  3. Moondog
    Moondog What's a Dremel?
    3 Jul 2007
    How thick is the plywood? I've seen wood bending done with very thin strips of wood soaked in water, then laid down of a heated pipe to purge the moisture and lock in the contour.
  4. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Normally they do it with thing strips( 1-3mm ), but I think it can be done with thicker pieces. You just have to apply hell of a lot of 'pressure' really slowly and patiently to make sure you won't break the piece. If you have one of those steamer thing that you use in cleaning I'd suggest you to try benging it with that one, If not, just use boiling water. But buy lot's of plywood just to test different mehtodes. Also go check out howstuffworks.com, they might have an article about the subject.
  5. Hugo.B
    4 May 2007
    I'd be using 6mm ply and for testing I'm using piece about 1'sq. trying to put a 90* bend in it.
    H.B.
  6. Isuo
    13 Oct 2004
    90°? That's going to be tough(sp?).
    Are you sure you don't want to cut it, screw it, sand it, epoxy- it and lack it (as in laquer?) ?
  7. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    You won't get a 90 degree bend in it, unless it's a large-radius bend - the ply won't take it, if only because the ply is made up of layers of wood with the grain at right angles to each other.
  8. Hugo.B
    4 May 2007
    ^^^I just found out the hard way.
    I'll investigate thinner plywood, and maybe acrylic, but then it wouldn't be wood.
    Undecided as yet.
    H.B.
  9. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    mitre joint?
  10. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Is it an option to relieve it with a few saw cuts on the inside of the curve? You can get quite a good bend that way, and you wouldn't need to steam it.
  11. Isuo
    13 Oct 2004
    Hmm, what you could do is to buy mahogany or balsa wood, because both are very thin...
  12. dutchcedar
    dutchcedar What's a Dremel?
    24 Oct 2004
    Plywood gets its strength and rigidity from the different layers running their grains in different directions and that resists bending.
    You can get some rather interesting and complex shapes from plywood, if you make it yourself. In other words, make a form, apply a thin piece of wood to it, cover it with glue, apply another layer of wood, repeat until you have enough layers and clamp well.
    Remember the school desk chairs from the sixties (am I dating myself?) and the "modern" furniture that followed... made from formed plywood?
  13. capnPedro
    11 Apr 2007
    Butt joint.
    hehehe
  14. Hugo.B
    4 May 2007
    You mean kerfing? I hadn't considered it yet, thanks for suggesting, I'll test it.
    Not having any wood thinner than 6mm ply right now, I'd have to mail order veneer, as unfortunately the best woodworking/DIY store nearby is B&Q.
    By the way, it was looking at and old bent ply school chair that gave me the idea of trying it.
    H.B.
  15. ElThomsono
    18 Mar 2005
    Yeah, I knew there was a name for it ;)
  16. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Google has 451,000 links. :search:
  17. Hugo.B
    4 May 2007
    I've realised I'll need better equipment than I have or can improvise, so I'll probably go with kerfing.
    Thanks all.
    H.B.
  18. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Surely wood is as thin as you cut it...
  19. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    How about some pics? :D
    What exactly are you trying to do? You can bend plastic to 90 degrees with a slightly rounded edge, or use a brake to bend some sheet metal.
  20. Hugo.B
    4 May 2007
    ^^^there'll be pictures in the project log, be patient.
    Or if I get really stuck, I'll post here again.
    H.B.
