Scratch Build – In Progress Steam & Current - final photos.
Discussion in 'Project Logs' started by awadon, 22 Nov 2010.
Should I change the color of the wood
Poll closed 2 Jan 2011.
  1. Don't change it.
    5 vote(s)
    41.7%
  2. change to mahogany
    5 vote(s)
    41.7%
  3. change to teak
    0 vote(s)
    0.0%
  4. change to dark brown
    2 vote(s)
    16.7%
Multiple votes are allowed.
  1. awadon
    awadon What's a Dremel?
    23 Jan 2010
    Another element. Placed vertically will mimic the liquid level meter.
    p0Pe likes this.
  2. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    I like it so far! +rep:)
  3. awadon
    23 Jan 2010
    I approach to the end. This is handle of the LCD matrix.
    So we have a hinge made of brass tubing and a pleated collar - from the old camera - where I will put the matrix tape.
    Because I can't show everything after mounting all together, there is a picture of all elements.
  4. awadon
    23 Jan 2010
    "Box" practically ready. The first waxing. Next week, the LCD assembly.
  5. awadon
    23 Jan 2010
    Fixing the matrix - that was the hardest step for me - already done. You can see the hole for the matrix wire.
  6. awadon
    23 Jan 2010
    I've started mounting all parts together.
    Now fast quiz:
    Which mount of VFD lamp to choose:
    VER1.
    VER2:
    And maybe some other ideas ???
  7. Baekkel
    Baekkel Picky Picture Villian
    17 Jan 2010
    i personally think mounted on top is the best choice.
    Looks banging together with the analouge meter, gives some kinda "high tech meets classic electronics" kinda feel about it.
    (even more than the entire steampunk idealism does it self..)
  8. Xye
    Xye What's a Dremel?
    21 Nov 2010
    I would say Version 1... only because I would be tempted to try and pick it up by that if it were on top. If it can take the weight then it looks better on top.
  9. awadon
    23 Jan 2010
    Today I was testing VFD control. Thanks to uncle google and a few tests I've made all electronic. I've used CNY 17 phototransistor. Each cell is a single chip. For now, all tied "shortly. " Tomorrow or next week I will begin making the plugs properly.
    As you can see I chose the option to mount the lamp on top. Most people voted that way, and even those who chose the second option, it is only due to the filling of the space above the screen. But I guess You do not think that will be all:)
  10. megadega
    megadega What's a Dremel?
    15 Mar 2008
    Good Job !
  11. KidMod-Southpaw
    28 Sep 2010
    Awesome! Reminds me of my old mechano sets.
  12. awadon
    23 Jan 2010
    Minor modifications. Under a brass plate I've hidden mounting hole. Only this way I can reach it to fix the matrix.
  13. awadon
    23 Jan 2010
    Another small work progress.
    Now I have to all of you two questions.
    1. As I said the I will try to develop area above the screen . I purchased a set of tasteful lamps:) It will be only a decoration.
    And there is my question. Can someone suggest me a way of installation?
    2. And the second question. Do you think I should change the color of the wood?
  14. NavidsonRecord
    NavidsonRecord Where the bloody hell are ya'?
    5 Jan 2010
    I would have liked to see ebony but thats is expensive and heavy. maybe for your next project change the wood. Keep it the same for this build but maybe stain with walnut color and weather it a bit with sandpaper. Or even take it to a sandblaster and get a nice even blast to show the wood grain. To finish you hand rubbed satin Tung Oil. These would suit the brass fittings ans old school aesthetics.
    lol I'm a bit specific haha. Just an idea :confused:
  15. ringo
    ringo What's a Dremel?
    14 Jun 2008
    I like your work and your brass parts.
  16. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    This is just amazing. Good job man!
  17. awadon
    23 Jan 2010
    Another small update.
    And thanks to you all, for yours comments.
  18. awadon
    23 Jan 2010
    According to some suggestions, I decided to see how illuminated lamp will look like. Well, I have mixed feelings.
    This is the same lamp only photo taken with, or without flash. As you can see it clearly shines. Although I can adjust it by changing voltage, but the question is whether or not is it worth. It starts to look like a Christmas tree. Although I do not deny that lamps usually shine a little.
    And if I decide to use led, what color to choose? Yellow, where such lamps shine, or something else?
  19. NavidsonRecord
    5 Jan 2010
    looks great!!! Sweet valves! Just a LED underneath?
  20. awadon
    23 Jan 2010
    Yeap. Only white led.
