Scratch Build – In Progress Steam & Current - final photos.
Discussion in 'Project Logs' started by awadon, 22 Nov 2010.
Should I change the color of the wood
Poll closed 2 Jan 2011.
  1. Don't change it.
    5 vote(s)
    41.7%
  2. change to mahogany
    5 vote(s)
    41.7%
  3. change to teak
    0 vote(s)
    0.0%
  4. change to dark brown
    2 vote(s)
    16.7%
Multiple votes are allowed.
  1. awadon
    awadon What's a Dremel?
    23 Jan 2010
    Well, another dilemma:)
    I came up with three mounting options. As the lights are above the screen, I would like them to be mounted parallel to the screen. Then they will be most visible.
    VER1.
    The combined system of "tubes" as a module.
    VER2.
    As above, but without "caps".
    VER3.
    Separate modules.
    And which kind you like it most?
  2. NavidsonRecord
    NavidsonRecord Where the bloody hell are ya'?
    5 Jan 2010
    version 2&3 look great. mounting them solo looks neater then group. But all look great
  3. awadon
    23 Jan 2010
    The sample color. Dark mahogany. I'm still not convinced to change:)
  4. NavidsonRecord
    5 Jan 2010
    mahogany is a very red color. try walnut and dont forget to apply the finish you intend to use to really show the color it will turn out like.
    Here is one of my guitars. Its Ash timber (I think thats what you used) with walnut stain applied thin, with cotton wool and then sanded back until desired color was reached.
    I applied a small amount of satin tung oil to show the color. you could go even darker.
    bulldogjeff likes this.
  5. bulldogjeff
    2 Mar 2010
    This thing is as awesome as it is mad. It looks like it should be mounted next to the wheel of a ship about 200 years ago. Absolutely loving this...+rep
  6. Krog_Mod
    Krog_Mod What's a Dremel?
    23 Sep 2003
    I did vote for mahogany, but now that i look at it again it just looks too dark. I honestly think you should just put a couple nice coats of shellac on it. If you use the french polish method on the maple it can really bring out the grain and make it look beautiful. Beeswax goes nicely over top of a shellac finish as well and makes it shine even more.
  7. ThirtyQuidKid
    ThirtyQuidKid Minimodder
    11 Jun 2010
    I voted don't change it.
    Brilliant work on this.
  8. awadon
    23 Jan 2010
    Thank you all for yours interest and suggestions.
    Today a small update.
    Lamps - the next version.
    And the most important thing. I did a sample of colors.
    Picture in daylight:
    And a series with a flash as usual.
    I put pieces of brass and copper to make a comparison. At the same time on the left you can see the section of wood with no changes.
    From the right we have:
    - lac/shellac
    - Wax - dark walnut
    - dark walnut stain
    Shellac with wax can be combined. Does any option is similar to your wishes?
    It is hard to get a good picture without proper light :)
  9. NavidsonRecord
    5 Jan 2010
    ah the pics dont work!
  10. awadon
    23 Jan 2010
    Pics should work. Maybe Your IP is blocked?? You don't see last one, or all of them?
  11. NavidsonRecord
    5 Jan 2010
    they are showing now but weren't last night. They look good! shame about the light. did you prep sand the test piece before staining?
  12. The_R1_Kid
    The_R1_Kid What's a Dremel?
    25 Nov 2010
    Wow. I will be following this. Great stuff.
  13. Altron
    Altron Minimodder
    12 Dec 2002
    Can you run some electricity through the tubes? Some of the metal pieces inside should glow a nice reddish yellow once the tube is on. Even if you're not doing anything, simply running electricity through the correct pins should make them glow. I think that would look far nicer than lighting them from below with LEDs
  14. NavidsonRecord
    5 Jan 2010
    you would need far more than 12volts to get valves glowing is the only problem.
  15. ringo
    ringo What's a Dremel?
    14 Jun 2008
    My favorite is the last version of the lamps.
    I think the lac/shellac painting is a little bit to yellow, I like the other paintings more. They look more noble.
  16. awadon
    23 Jan 2010
    Thank you all guys for yours professional advices. It's nice feeling, that someone is reading it :)
    And most importantly, that councils give people knowing what is shellac and how to work with the wood.
    No. My mistake. I've wanted to show you results fast. That's why it looks little "scratchy".
    I've tested lamps. Yes. They looks great! But..... They consume more than 60W. I can't afford that loose of power for nothing. I will show you next week results with red laser led. Should be fine.
    For today.
    I've installed the operating system. Fortunately, everything works and nothing broke in the tests.
    And so it looks like after the lamp mount.
  17. NavidsonRecord
    5 Jan 2010
    With stains its very important to have it perfectly sanded or the stain looks patchy and scratchy. I like the center one btw. the stain seeps nice into the veins of that timber.
  18. Krog_Mod
    23 Sep 2003
    I do like the look of the stain in the middle and I really like how the shellac made the grain sorta glow. I'd be interested in seeing how the stain looked with shellac over it. I think I'm just a sucker for warmer feel of shellac though.
    If you do go with the shellac I'd suggest using a lazy version of the french polish so you don't get the streaks. You can also lighten the color a bit if you thin the shellac with denatured alcohol.
    Lazy man's french polish: get a clean cotton cloth and ball it up so you have a pad sorta thing, dip in for some shellac and rub it on in a circular motion and just keep going till it's shiny and nice. When you're done with that, wait like 30 minutes then use some #000 steel wool on it and then apply the beeswax if you want to shine it up even more.
    I'm seeing a lot of nice figure in that wood, so I can't wait to see how your finish will bring that out.
  19. DeadP1xels
    30 Nov 2009
    Wow this is wicked!!
  20. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    That is just funk'in cool!! Great work!
