Case Mod - In Progress Steam Punk but more chic
Discussion in 'Project Logs' started by madmodmole, 27 Aug 2012.
  1. Owndapwn
    Owndapwn What's a Dremel?
    13 Jul 2012
    Subscribed.
    I like what I see. Good job.
  2. madmodmole
    madmodmole Another warranty bites the dust....
    10 Aug 2012
    Hello again everyone, sorry about the delay been busy lately, but at least there will be a nice long post as I have now almost finished the mod.
    There has been a change of plan from using the fan to a servo now as I can easily gear it to move at the right speed.
    [​IMG][/IMG]
    [​IMG][/IMG]
    Next I drilled a hole for the servo head to fit into in order to drive the cog.
    [​IMG][/IMG]
    [​IMG][/IMG]
    Before I started on the 'cog and piston' I gave the side panel a respray in copper and finished off the edging around the windows to make them stand out more.
    [​IMG][/IMG]
    Time to work on the cog and piston :)
    The Cog was cut out of plasticard and then filed into shaped with the help of some clippers.
    [​IMG][/IMG]
    This was the sprayed black ready to be painted to make it more rusty.
    [​IMG][/IMG]
    Next I got to work on the piston and how it would be able to slide up and down. Drew a few sketches first.
    [​IMG][/IMG]
    This would also be made out of plasticard and then painted later.
    I was made using 3 layers of plasticard in order to make a slot in the middle for the arm to run up and down.
    [​IMG][/IMG]
    [​IMG][/IMG]
    I used an old circular servo arm as the runner and chopped down the sides so it would fit.
    [​IMG][/IMG]
    [​IMG][/IMG]
    Next I started work on the piston. This was also plasticard with some metal bits I found in a draw at the end. Have not got a clue what they were from. :)
    All of these were then sprayed black.
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    The cog now needed a point for the piston to rotate around and this was just a screw with some plasitcard to raise it off the surface.
    [​IMG][/IMG]
    This was all then attached to the cog and servo and then stuck on to the panel.
    [​IMG][/IMG]
    I then started to paint some detail onto the piston mounting.
    [​IMG][/IMG]
    At this point I started to work on the motherboard.
    I painted the cpu fan and also added several details which were built out of card board then painted.
    [​IMG][/IMG]
    The overall affected I was quite pleased with.
    [​IMG][/IMG]
    Next I decided I needed something to cover my hard drive so ... out came the warhammer again.
    I painted up some panels which could fit over the hdd.
    [​IMG][/IMG]
    In the end I decided on this one.
    [​IMG][/IMG]
    [​IMG][/IMG]
    More work has been done but I have not taken any photos yet hope to update soon.
    :D
    Fuganater likes this.
  3. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Looking good! Love the gear on the side panel.
  4. dreps
    dreps Minimodder
    3 Oct 2012
    can"t wait to see this finised :D
  5. ziza
    ziza What's a Dremel?
    21 Dec 2010
    I got the feeling This will be one of those projects :jawdrop:
