Case Mod - In Progress Steampunk/Dieselpunk Computer MK2, 24th of January
Discussion in 'Project Logs' started by Wirecase, 24 Jan 2014.
  1. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Well I looked at it and thought of Angela Lansbury so you've done it right ! :D
  2. Nexxo
    23 Oct 2001
    IT'S SO STEAMPUNK I'M GONNA DIE!!!
  3. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
  4. LegendaryScott
    LegendaryScott Trying to live up to the name
    5 Apr 2013
    beautifully done
  5. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Well... I don't really know what to say... That's just so cool. There are so many great little features that you have included. I love the power cable, the cap really looks good with the rest of the build. It is a fantastic little touch, and the mouse scroll wheel is great. I'm going to keep a close eye on guys to see the finished project
    Sent from my Nexus 7 using Tapatalk
  6. Cheapskate
    13 May 2007
    Normally I boo at dismantling old tech, but these are very common still. I love what you have done too.:D
  7. Wirecase
    Wirecase What's a Dremel?
    16 Jan 2014
    Steampunk/Dieselpunk Computer MK2, 18th of February
    Hi guys,
    So first of all, Boorach, AlienwareAndy, Nexxo, Jumeira_Johnny, LegendaryScott, Dancingbear84 and Cheapskate... Thank you guys so much for the praise... I'm really glad you appreciate my work!!
    And, in reply to Cheapskate, I'm also not a fan of dismantling old tech. But, as I said in my first post, these 2 machines were beyond saving... The normal carriage one having badly, and I mean badly, rusted mechanics. And the wide carriage one missing parts and some things stuck and twisted, made me feel not so bad. A big plus is that I'm giving a combination of their good parts a new lease of life :)
    So, now on with the update!
    I do feel my machine needed speakers... As I'm still thinking on what to do I've chosen to have integrated, invisible, speakers for now. I've mounted a pair of small USB powered speakers inside the carriage. The thing is though, I'd really like to visible speakers in some way.
    What I was thinking of is a pair of small tulip shaped horns. At first I though they would sit at the sides of the monitor but, as it's already quite wide I'm looking into different placement. One option is to have them come out of the bottom of the carriage and curve upwards, but then I don't know how to mount the speaker part of the horns in a good looking way... The other option is to have the speakers separate on their own base.
    Anyway here's what I've been toying around with:
    I looked around for a pattern to make some horn shaped speakers. I printed the pattern to be 8 cm long and made a paper version first:
    Satisfied with the look and shape I decided to go on and make the metal versions, from left to right:
    1- Paper version
    2- Bare unshaped metal petal
    3- Curved in the width
    4- Curved lengthwise (finished shape)
    First one soldered, the edges still rough and the soldered joints a bit ugly because I set a too low temperature for the soldering-iron. Did it the right way for the second one...
    Cleaned up the solder joints by re-flowing them at a higher temperature and treated both horns to a nice coat of filler primer.
    The Idea is to finish them in black, high gloss paint... Or... remake them out of brass sheet and keep 'm as bare polished brass...
    That's where the speaker idea has stranded for now... I did however get the opportunity to go and take "project finished" pictures in a very nice location, but that's for the next post! :p
    Greets for now,
    Wire!
  8. Nexxo
    23 Oct 2001
    Brass! Brass! Brass! Brass! Brass! Brass! Brass! Brass! Brass!...
  9. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    This is just lovely.
  10. Wirecase
    16 Jan 2014
    Case Mod Steampunk/Dieselpunk Computer MK2, 5th of March
    Hey hey,
    After a few very busy weeks at work I'm back!
    First of all, @Nexxo, I will retry making them out of Brass then :)
    And, @ Mockingbird, Thanks man!
    So last time I was saying I would post some "project finished" pictures, sadly my camera is acting up so most of the pictures look a bit grainy :confused: anyway, here are the pictures:
    Some overviews
    And, some close-ups
    And something extra, a mouse I build a while ago that fits the style...
    Hope you like the pics! :)
  11. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    OMG, That is gorgeous. I do love the mouse too. Excellent job Sir!
    I have a desk similar to this one, except that it is in wallnut. It is currently under modification because it is too big to fit the door opening :facepalm:. I'm modding it to have the below part separable, everything is assembled the good'ol way (dove tails, morteses, etc.), not a single nails or screw.
