Modding Steampunk monitor stand
Discussion in 'Modding' started by lifer, 9 Mar 2010.
  1. lifer
    lifer Water on the pcb
    2 Jan 2009
    Hey all, Just wanted to share my latest mod. I have caught the steampunk bug lately and I really like the look of all the polished metal and wood.
    Case to come later.
    [​IMG][/IMG]
  2. nlancaster
    nlancaster Minimodder
    21 Dec 2009
    looks good, when you going to do the rest of the display?
  3. lifer
    2 Jan 2009
    Thanks, This monitor is going to my brother who wants a more industrial look hence no decoration but I do have another one which shall be getting the full steampunk treatment soon.
  4. Cheapskate
    13 May 2007
    I like the look of the cherry stain and the polished copper. They compliment each other well. What did you use to keep the metal bright?
  5. lifer
    2 Jan 2009
    Thanks dude, All the metal was polished by hand using sandpaper going from coarse to fine grade then liquid metal polish for final polish. Took a long time but worth the effort. It will require just a quick polish to maintain its apperance.
  6. Pookeyhead
    30 Jan 2004
    Looks cool!
    I'd actually let it tarnish and go dull. I think it's a little too crisp and clean for steampunk at the moment. I always imagine anything steampunk as a little careworn and funky.
  7. lifer
    2 Jan 2009
    Victoria
    As promised the case to match the stand is finally complete, so without further ado I proudly present Victoria.
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    Shes built from recycled rimu, a native red pine, which I stained mahogany for an old look. I based the design on a old writing desk. The hardware is pretty basic stuff as is fitting for a torrent box, later I would like to use it as a HTPC. DVD drive and usb port with mouse receiver are both under keyboard shelf. Keyboard is not wirelss, I chopped its usb plug off then drilled a small hole and threaded it so it is internal then soldered its plug back on and connected to a usb port. The worst part would be sanding/polishing the 90 degree copper pipe connectors by hand, each one took almost 2 hours to do and theres lots of the little buggers. Even though its taken me 6 months work im very happy how it turned out.
  8. Infiniti
    Infiniti i modded the wheel!
    3 May 2009
    i love steampunk :D
  9. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    I want to build a case which uses those copper pipes for water-cooling tubing now... With a glass ball on the front for checking coolant levels...
    *stops studying and goes off and plans*
  10. Nanosec
    Nanosec absit iniuria verbis
    28 Apr 2009
    Beautiful work, and I have just a thought. what about making a removable cover that would essentially hide the keyboard when not in use. I think it might take this from being a cool computer case to a peice of functional furniture.
    Just a thought.
  11. jcooper138
    jcooper138 Steampunk newbie
    8 Oct 2010
    Well done. Beautiful work really. Especially the polish on the copper.
    Where did you get the gauges?
  12. zatanna
    zatanna What's a Dremel?
    15 Oct 2010
    wow, this is really beautiful! congrats. i know some steampunksters that would drool over it.
    i am.
  13. lifer
    2 Jan 2009
    Thanks guys, The gauges were sourced from trade me and ebay. I am looking for a pocket watch to go with it now, it never ends does it.
  14. RabidCicada
    RabidCicada Minimodder
    21 Oct 2010
    This is great:)...I'm thinking about creating the Brass Iris Garage opener that this guy did. I've never beena huge steampunk fan myself....but it really does look nice:).
  15. lifer
    2 Jan 2009
