Scratch Build – In Progress Steel box PSU
Discussion in 'Project Logs' started by Tipchic, 19 Feb 2010.
  1. Tipchic
    Tipchic ***
    3 Jul 2008
    Hi 2all! )
    Once I have bought a SFX PSU, and have decided to make the small sizes PSU.
    Inwin 300W.
    In comparison with the standard ATX PSU.
    So, begining... .
    Chap. 1. )))
    Steel 1.2mm. Cut out with jigsaw.
  2. Tipchic
    Tipchic ***
    3 Jul 2008
    Chap. 2.
  3. Tipchic
    Tipchic ***
    3 Jul 2008
    Chap. 3.
    Cut out with "dremel".
  4. Tipchic
    Tipchic ***
    3 Jul 2008
    Chap. 4.
  5. Tipchic
    Tipchic ***
    3 Jul 2008
    Chap. 5.
  6. Tipchic
    Tipchic ***
    3 Jul 2008
    Next step: paint.
  7. Tipchic
    Tipchic ***
    3 Jul 2008
    The final.
    Russians coming...
    confusis likes this.
  8. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Did you solder it together?
  9. Tipchic
    Tipchic ***
    3 Jul 2008
    Yes, only solder. :D
  10. confusis
    confusis Kiwi-modder
    5 Jan 2006
    wow that's brilliant!
  11. confusis
    5 Jan 2006
    build one for me?
  12. MugenUK
    MugenUK What's a Dremel?
    5 Aug 2008
    Looks great mate.
  13. Tipchic
    Tipchic ***
    3 Jul 2008
    confusis, MugenUK, thank you! )
    Javerh likes this.
  14. PimPin>PC
    PimPin>PC NZ Modder
    15 Feb 2010
    Wow that looks great :hip:, i want one too :clap: you have given me a few ideas for my own build, chers mate :D
  15. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    looks awesome :eek:
    one question though, how will you mount it to a case ? i see no mounting holes on it
  16. bagman
    bagman Minimodder
    18 Apr 2009
    that is pretty damn neat
  17. Tipchic
    Tipchic ***
    3 Jul 2008
    PimPin>PC, it's good :)
    Dark~3nergy, pertinent question :thumb:
    I have some variants.
    L-shaped member, strainer etc.
    Custom PSU for custom case. )
    bagman, thanks. )
  18. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    :jawdrop: fantastic
    Looking at your pics it seems you used something like "fluid steel" (a glue) to connect pieces.
    The only thing that didn't make me crazy are the two small fans....i think one slim fan like scythe slip stream could be better in term of noise ;)
    I' am curious to see the case :dremel:
  19. Tipchic
    Tipchic ***
    3 Jul 2008
    Dot_Kappa, thanks!
    I use only solder iron 100W and 60% solder. (60%Pb/40%Sn) Glue is s***.
    PSU is very quiet. ;)
    Stock fan 0.18A, new 0.17Ax2. It work at 1/4 max power.(PSU have automatic control)
    If i use scythe, what i do with power connector? :eyebrow:
    I'am too.:D
  20. Dot_Kappa
    23 Mar 2006
    :D
    The scythe fan is a 3 pin one, like yours.... red ,black, and yellow wire.
    You need to connect only red and black to the voltage regulator as you have already done.
    Check if the power consumption of the scythe is higher or lower than the original fan in order to prevent the burning of your controller ;)
    The little green component in the photo is the sensor of the regulator.....
