News Stereoscopic 3D gaming is really cool
Discussion in 'Article Discussion' started by Tim S, 26 Aug 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    This isn't exactly new new tech though... Someone (I forget who:rolleyes:) demoed a stereoscopic screen at my old school last year that didn't use glasses at all - as long as you stood i nthe correct area, which wasn't exactly small either, it appeared in 3D. He showed us an animation of a waterfall and it was pretty amazing. They were doing large sizes too if you paid enough.
    And even so, 3yrs ago I was using LCD Shutter glasses on my 21" CRT @ decent res, and a year before that I was using coloured glasses on an LCD projector!
    These ideas / technologies have been around for ages; either no-one's pushed it hard enough or consumer demand just isn't there:sigh:
  3. Tim S
    Tim S OG
    8 Nov 2001
    It's been around for a while - it's been in 3D cinemas since I don't know when... but the technology has been refined quite a bit since then and it's actually starting to get close to something that can be productised.
  4. Xir
    Xir Modder
    26 Apr 2006
    Welcome to the Year 1999.
    German firm Elsa* brigs you the Revelator... a 3D-glass that works with LCD shutters.
    http://www.stereo3d.com/revelator.htm
    Available in cable bound and IR-Wireless version!
    So much for the Nvidia Idea.
    I used it back in 2000...problems were:
    a) finding a CRT-monitor that runs at >150 Hz at a decent resolution (better yet 200).
    As if effectually cuts your Hz in half for each eye, and you'll nees AT LEAST 75 Hz on a CRT...preferabbly 85 to 100.
    b) nauseating effect over time
    Played Half life (one) with it. Supercool!
    Xir
    *actually they also bougt it from someone
  5. kenco_uk
    28 Nov 2003
    I think you've got it wrong, because..
    ..sounds a bit different.
  6. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Its the same tech, IMax ciniema uses polarised lenses which being a passive system do not flicker on and off like the LCD shutters, also the way IMax works with its polarised lenses is by using 2 projectors projecting onto the same screen, one projector with a vertical polarisation and the other with a hortizontal polarisatoin.
    Where as the LCD shutters are an active system, ive a set of the edimensional 3D Glasses a few years back which use the LCD shutters, its very effective when you tune it right, but found that different games needed setting up acordingly which would take a while, I recall Dawn Of War, getting the image to look awesome in the menu, but then once in game, having to re-tune the 3d effect so that it looked correct in game.
    As Xir says, you need a REALLY high refresh rate monitor for best smoothness otherwise it does look a bit jerky and can strian the eyes, also from what I noticed when wearing them, the display is half as bright as it was before, so idealy needs to be used in a darker room.
  7. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    +1, although it sounds cool and all but what if you already wear glasses (and can't see for toffee without them)
  8. Arkanrais
    Arkanrais What's a Dremel?
    14 Jul 2007
    I'd prefer the stereoscopic headsets that have 2 OLED screens in them, one for each eye. instead of using shutters, it has 2 simultaneously running screens with (I think) a slightly displaced camera angle on one of them. the one I saw also had motion trackers inside it so you could move your head a full 360 horizontal and 60 degrees vertical. unfortunately the one I saw only went up to 800x600 pixels and acted as a single CRT screen and would essentially be taxing the GPU as if it were a 1600x600 screen. it also had built in headphones for virtual surround sound.
    still, it would be cool having a run around on oblivion or fallout 3 and be completely immersed in the game.
  9. Xir
    Xir Modder
    26 Apr 2006
    The Elsa glasses worked really well...used the Z-Buffer information (that was used in most games anyway) for depthinfo.
    Everything 2D (Menu's) looked a bit strange though.
    IF you get a high enough refresh rate monitor, you've got the full resolution per eye, but brightness only one eye at the time, so it seems darker. Finding a monitor that would do 1024x768@170Hz or even 1280x1024@170Hz was the problem.
    Also Fun...returning the borrowed monitor and NOT reducing the 170Hz setting in windows before you disconnected it. Then connecting your own monitor and getting a black screen (out of range). Try resetting that in Windows! :-(
  10. Lowsidex2
    Lowsidex2 Minimodder
    29 Sep 2003
    I like the guy that used the wii remotes to track head movements to make his 3d display. http://www.youtube.com/watch?v=Jd3-eiid-Uw
    Much cooler idea IMO. Still need some kind of head gear but not using shutters has to be easier on the eyes.
  11. Anakha
    Anakha Minimodder
    6 Sep 2002
    That is easier on the eyes, but it still appears 2D. There is no stereoscopic effect with Johnny Lee's system, so while it IS moving like it should be 3D, it isn't.
    However, if you combined that with a 3D system like the one in the article (Or even the old shutter glasses system), you'll have full 3D realism.
    Oh, and if you want cheap 3D stereo effects, all NVidia graphics cards (With the driver bits) support using Anaglyph (The Red/Blue glasses) to make Stereoscopic 3D in any 3D game. http://www.nvidia.com/object/3d_stereo.html And it's not just the most recent ones, that's just the drivers. Older cards are supported using the "Legacy Drivers" - I've had it working on a GeForce 4MX.
  12. Xir
    Xir Modder
    26 Apr 2006
    Ehmmm, the point here is: the system in the article IS the "old shutter glasses system"
  13. kenco_uk
    28 Nov 2003
    No it isn't. The old sort relied on polarised lenses that 'shuttered' (sort of slowed down the refresh rate of your eyes to create a pop-up 3d effect, like wearing those red and blue filtered cardboard specs you got free with comics). This system uses 'mini LCD screens that sync with the PC via an infra red sensor that sits down by your keyboard – this ensures that the correct image is sent to each eye and there is no loss of resolution'. Does the same thing, but technically very differently.
  14. Delphium
    18 Mar 2007
    Actually due to the nature of the LCD technology, them LCD shutters are still polerised, just 1 eye is open and other closed, then it switches... Just like the older style... I bet if you tilt your head 90degraes sideways and looked at an LCD pannel, the image would pritty much disapear, due to the LCD polarization.
  15. Xir
    Xir Modder
    26 Apr 2006
    Nope...the "Old" system also used LCD screens in the glasses, which shuttered...they turned black and transparent.
    One eye black, the other transparent, screen shows one picture.
    One eye transparent, the other black, screen shows second picture.
    Both pictures together create in the brain a 3D-picture.
    The same can be done without shuttering, with polerized lenses, one polarized vertical, the other one polarized horizontally.
    one picture is only seen by the one eye, the other by the other...same effect as with shuttering.
    But with shuttering you don't need polarized pictures, which is better for the colour quality.
    (Read the Link: http://www.stereo3d.com/revelator.htm )
    Xir
  16. kenco_uk
    28 Nov 2003
    Ah.. I see (pun intended). Huh, well the way I understood it to work is about as different as it could be then :)
    Everyday is an education.
  17. Delphium
    18 Mar 2007
    Just a thought Tim... did/do these new glasses work on vista, and with dx10 gfx cards?
    Edit: also the articles link to the forums still points to the forum home page rather than this thread.
Tags: Add Tags
