Networks Stick with 802.11n or upgrade to ac??
Discussion in 'Hardware' started by AT0MAC, 2 Aug 2013.
  1. AT0MAC
    AT0MAC Pirate Captain
    8 Jun 2008
    My network is today made up of a home router from my ISP that has very crappy wifi coverage, so disabled it and am using a Asus EA-N66U access point to broadcast for me.
    My current mac dont have wifi build in and I now want to move it to a new placement where cabling would be really difficult - I am therefor considering if I should just get a matching Asus USB-N66 adapter and keep using 802.11n network - or should I go all in and buy two Apple Airport Extreme AC adapters instead??
    Is AC network really SO much better than n that they are worth 4x the price per piece?
  2. djzic
    djzic Bokehlicious!
    8 Nov 2010
    AC has way more throughput but if your internet is only 50mb/s say then it's not really worth it.
  3. GoodBytes
    20 Jan 2007
    AC is still in draft, you take the chance like early Wireless N adapters to be stuck in buying a new wireless N router because the new draft version, which your new device support doesn't work with the old draft version.
    If you want faster, look into getting a dual band wireless N router for your dual band wireless N ready devices, if any.
