Windows Sticky Keys
Discussion in 'Software' started by Melov, 28 Mar 2004.
  1. Melov
    Melov What's a Dremel?
    30 Apr 2003
    Anyone know how to disable this crap in windows? It's soooo annoying. Press shift 6 times and bam it pops up and I get alt tabbed outta my games so it can ask me if i want to enable sticky keys! Help me disable this!
  2. Kermet
    Kermet [custom title]
    18 Feb 2003
    Anoying isn't it, almost as bad as when I had a KVM switch that switched the monitor with a double tap of ctrl and it couldn't be disabled...
    Control Panel -> Accessibility Options -> Keyboard -> Settings (StickyKeys)
    Once there make sure 'use shortcut' isn't ticked.
  3. batsman
    batsman the quiet one
    14 Nov 2001
    cover the keyboard durring one handed surfing :D
    sorry couldn't resist
  4. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    just do like it says, "to disable, click settings" click settings, then click settings for stickey keys, clear the box for "use the keyboard shortcut" then hit OK untill you are out of the dialog boxes.
    Sometimes you can figure out something if you read the box instead of higgint cancel or OK or escape right away ;)
