Modding Sticky Stuff Removal
Discussion in 'Modding' started by The_Crapman, 14 Aug 2012.
  1. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Ahoy hoy modderinos!
    My case is plastered in foam pads which need removing before painting, but they leave a nice sticky tackyness all over the place. Anyone got any tips for removing it?
  2. digitaldunc
    digitaldunc What's a Dremel?
    4 Oct 2010
    Pure alcohol should do the trick.
  3. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    peel them off and remove as much as you can then use wd40 on a cloth / rag to remove the sticky stuff.
    ask wife / Gf if she fot any Nail Polish Remover if no wd40.
  4. mingingbollock
    mingingbollock Minimodder
    15 Mar 2004
    +1 for iso alcohol , search ebay for IPA , dirt cheap for a little bottle
    and will last you ages , cleans anything
  5. Elton
    23 Jan 2009
    If its plastic,Wd40 is the safest bet. Acetone or alcohol may corrode plastic. If its metal, wd40.
  6. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    I used 99% IPA on plastics without ever having issues - Acetone totally different story :p
    I tend to use a plastic scraper to remove as much from metals as I can. Heating with hair drier helps too as sometimes the sticky pulls away easier.
  7. Teelzebub
    27 Nov 2009
    This I use a WD40 pen works great every time
    YEHBABY, Apophis54 and Pookeyhead like this.
  8. The_Crapman
    5 Dec 2011
    Cheers guys. You'll see me on the news tomorrow flying high round the sky ;-)
  9. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    Furniture polish too some good old Mr sheen
  10. Tangster
    23 May 2009
    Anything that can clean TIM removes sticky residue in my experience.
    Apophis54 likes this.
  11. mingingbollock
    15 Mar 2004
    also seriously flammable :thumb:
  12. The_Crapman
    5 Dec 2011
  13. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    This works wonders for sticky stuff.
  14. David
    7 Apr 2009
    Akasa TIM clean.
    Brilliant for removing sticky residue.
  15. Wissel
    Wissel What's a Dremel?
    12 Aug 2012
    As others have said a good TIM cleaner. I use Isopropanol, works a treat.
  16. Tynecider
    Tynecider Since ZX81
    23 Jun 2009
    TIM cleaner smells, looks and acts just like Goo-Gone which is also a lot cheaper.
    Apply to the area, let it sit for 15 mins or so, wipe off with a soft cloth and minimal effort.
  17. The_Crapman
    5 Dec 2011
    i ended up using akasa tim cleaner as i had a full bottle to hand. worked brilliantly! cheers guys.
