Other Storing Computer Components
Discussion in 'Hardware' started by Whitlog, 16 Mar 2009.
  1. Whitlog
    Whitlog New Member
    26 Jul 2004
    I have ended up with a few Parts such as Mobo, HD etc, I have them all carefully placed in a big shoe box, Will they be ok in this or is there a better way to store them?
    Thanks:thumb:
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Keep boards in an antistatic bag if you have them, and it's a good idea to store manuals and driver discs with them.
    Shoe boxes = Cheesecake
  3. Whitlog
    Whitlog New Member
    26 Jul 2004
    ok thanks
    are they easy to get hold of or do you have any on-line recommendation to purchase them?
    Thanks
  4. capnPedro
    11 Apr 2007
    A local PC shop should provide you with some for free. OEM builders get thousands of the things.
  5. Whitlog
    Whitlog New Member
    26 Jul 2004
    Thanks
    was looking online but then some seemed different to others, some just anti static some with metal out, was not sure if it matters which I got etc , but will pop into my local shop next time I get chance
  6. capnPedro
    11 Apr 2007
  7. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    dont be too tempted to sling them into a handy ikea plastic tub, plastic usually means evil static energy! ah! even tho you'll be surprised at what sort of abuse hardware can take.
    I've seen people handle hardware as if its an extremely sensitive biological bomb about to go off at any time. Its all a little funny!
    Cardboard and anti static for the win!
  8. Mokey Mokey
    Mokey Mokey New Member
    9 Mar 2009
    Ha ha, thats me. I always think I'll bust a capacitor off or something.
  9. Snuffles
    Snuffles Dreamy Mammoth
    24 Feb 2009
    DUDE how BIG are your FEET!!!!
    Try to keep the original boxes just in case of RMA, unless you wear Size 18 EEEE sneakers like Whitlog.
  10. Whitlog
    Whitlog New Member
    26 Jul 2004
    Ye ok I can see how that seems, in fact they are just size 12, its my girlfriends shoe box that had a pair of boots in them, maybe I should of called it a boots box but then I might have you all wondering a whole different question!!...............................I am only called Susan on weekends anyway :D
    Cheers for all the info, its much appreciated! :thumb:
  11. Burnout21
    9 Sep 2005
    I find shoe boxes good for storing graphics cards and HDD's, i tend to keep the motherboard boxes as there very handy.
  12. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    You mean you can't just pile them on your desk?? :D
  13. steveo_mcg
    steveo_mcg New Member
    26 May 2005
    Always worked for me.
  14. capnPedro
    11 Apr 2007
    Anyone else notice that the amount of spare bits/unused mounting hardware/manuals/driver CDs left over from a build fits perfectly in a PSU box?
  15. Combinho
    Combinho Ten kinds of awesome
    5 Aug 2008
    Yep, and all the other boxes fitted ino the case's box.
  16. steveo_mcg
    26 May 2005
    Which all fit in to my old Cheiftech, ahh symmetry...
  17. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I've tucked them all into my mobo box, it's a tight fit, but they do indeed fit.
  18. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    lol, thats what i do, pile them on my desk or in empty diaper wipe boxes (those things are quite useful, fits an old PCI card almost perfectly)
