Hi, I have very strange anomalies on my screen kinda like space invaders green and pinky in colour. Mainly hit while browsing the web: http://i90.photobucket.com/albums/k276/pixum20/Capture.png
furmark is a GPU stress/stability program. what prime95 does for CPUs, furmark does for GPUs. your video card may be failing on you, its a good idea to check it out.
Tell us what hardware you have pixum20 and don't stress the GPU yet! It might tip it right over the edge, be better to edge on the cautious side for the moment.
cpu: q6600 @2.40ghz mobo: asus p5n-d ram: 4GB corsair xms memory Video card : gainward geforce 250 gts 512mb running windows 7 64 bit Does this help?
I have just bought a cheap graphics card online to see if i have same problem with that. oh and i have a dell sp2309w monitor. 23.5 inch full hd, 2048x1152 native resolution. i have given my system a full dust out. still same.
intel q6600 2.4 ghz gainward geforce 250 gts 512mb graphics asus p5n-d mobo 4gb corsair xms memory I have just purchased another cheaper graphics card just to check it's nothing else.
gonna go new build route total overhaul http://forums.bit-tech.net/showthread.php?p=2697552#post2697552
Sounds like GPU artifacting to me... clean out the dust and check temperatures, and I assume it's not overclocked right? If possible try testing with another card to rule out the display itself.
I'd suggest uninstalling flash for a bit. Weird yeah but I had this weird problem where the whole screen went insane with a bit of flash use. Hey its an idea is all.
