Graphics Strange gaming problem.
Discussion in 'Hardware' started by Kronos, 23 Mar 2018.
  1. Kronos
    Kronos Well-Known Member
    6 Nov 2009
    So far I have had this problem which I know I am going to have trouble describing accurately with three games.
    Assassins Creed: Origins.
    Far Cry 3.
    Ghost Recon: Wildlands.
    With Origins it happened after a patch so assumed that was the cause. With Far Cry 3 I noticed after installing the game but assumed it was a driver thing being a 5 year old game and I have just reinstalled Ghost Recon after buying the DLC Narco Road.
    The issue is movement, there may be a nano second of lag when I move the mouse this means the view does not have its usual sharpness until I stop moving.
    I am currently reinstalling Crysis 2 a game I played a few weeks ago and which was perfect.
    Whether there is any relationship between the issues I am having with games and the Oculus Rift I installed at around the same time has crossed my mind.
  2. Kronos
    6 Nov 2009
    Over 40 views and not even a suggestion or question?
    Fortunately over on another forum a suggestion was made which seems to have resolved the issue and it may well have been something to do with Share Mouse software.
  3. Arthur
    Arthur Comment is over there ----->
    24 Nov 2009
    Do you have share mouse software installed ?
    Might be that
    alfizzle and Vault-Tec like this.
  4. adidan
    25 Mar 2009
    I viewed it. I had no suggestion. Glad you got it sorted. Pesky mice.
  5. Vault-Tec
    30 Aug 2015
    haha :D I was going to post and say "40 people are not using Share Mouse.."
  6. Kronos
    6 Nov 2009
    Not so long ago there would have been 40 suggestions, the forum is a shadow of its former self.
    Shame but there you go.
  7. adidan
    25 Mar 2009
    Posting at 4pm on a Friday at the end of work before a weekend and you go on a downer about the forum?
    Jeez dude. Something bothering you?
    bawjaws likes this.
  8. Vault-Tec
    30 Aug 2015
    There wouldn't, because when it comes to software it's a minefield. I read your post and I had no idea what could be causing it. None. Would you preferred it if I posted and said "No idea dude"? I did read your post and if I could have helped you I would have, but I had no idea.
    I had a similar issue once, but it turned out to be the touch screen driver for the little screen I bought from Byron. It was making the DK2 continually add/remove from DM with the noises associated and the PC was lagging bad. But that was irrelevant to what you were describing.
    adidan and bawjaws like this.
  9. Kronos
    6 Nov 2009
