Windows strange turn ons (not those kind)
Discussion in 'Software' started by I'm_Not_A_Monster, 24 Dec 2004.
  1. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    my computer is running XP and everytime i shut the computer down it turns back on after about a half hour.
    i did have it set to always on but I've since changed it to home setup. i also left it on overnight for a week or so (while it was assimilating my t*rr*nts that i was doing)
    also, how can i get the computer to turn completely off when i shut down, it just does that "it is now safe to turn off your computer" crap
    i am a total n00b to XP, i have always used 98se.
  2. CyberSol
    CyberSol 1337 Pants
    18 Oct 2004
    The reason it says "It is now safe to turn off your computer" in short is because the powersupply or motherboared doesnt support advanced power mangagement.
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    which is wierd because it turning itself on implies the network is waking it.
    [Disable Wake-On-LAN) in the BIOS.]
  4. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    Some do wake on ring too.. But I'm sure it would be obvious if your PC turns on when the phone rings.. :)
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    I always thought w-o-ring refered to the network! but that makes so much more sense...
  6. mottl3y
    mottl3y What's a Dremel?
    1 Nov 2004
    there are options in your bios to change advanced power management. try fiddling with them i guess :naughty:
  7. Kermet
    Kermet [custom title]
    18 Feb 2003
    My flatmate had a midget clown fetish, don't live with them anymore...
    Sorry, only partially read title...
    Try another power supply, a friend of mine's computer used to just randomly boot up (WOL, WOM , WO-EVERYTHING-ELSE was turned off). Popping in an old power supply of mine sorted it out straight away, never did investigate it either.
  8. I'm_Not_A_Monster
    22 Dec 2003
    HIM TOO!!! OMG, we should start a support group!
    three foot tall person with a face like this :blush:
    :baby:
    I'll try fiddling with the BIOS next chance i get, the computer i have is my old one but with a new HDD, but with the old HDD it shut down fine.
