Networks Streaming HD
Discussion in 'Hardware' started by drjaydee, 10 Sep 2011.
  1. drjaydee
    drjaydee What's a Dremel?
    1 Sep 2009
    Hi
    I need advice on home networking. I have a main PC which has most of my video and music content on, but I want to be able to stream it around the house to laptops and an xbox and PS3.
    The main PC is close to where the phoneline comes in and is currently wired into the freebie wireless-g router that came with the internet.
    My main concern is a router that is good enough to handle more than one source trying to access files on the same PC, will increasing to wireless-n improve the situation? Is gigabit internet a worthy investment, or overkill for what I need?
    Any advice would be greatly appreciated.
    Many thanks
    Nick
  2. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    (you mean gigabit Ethernet)
    Wireless n would be needed pretty much, gigabit Ethernet would be recommended though you could get by without it, it's useless for the xbox as it doesn't have gigabit ports just 100mbit
    Id say definitely put the PS3 on Ethernet either 100mbit or gigabit its only got wireless g
    Though if I was you id get a wireless n router and a gigabit switch and id be running everything off Ethernet only using wireless for laptops
  3. drjaydee
    1 Sep 2009
    your right i do haha. excuse the slip.
    are there any particular manufacturers/models you would recommend? would a dual-band one be best? what's the sort of price differences between a good router with gigabit and a roughly equally good one without?
    Many thanks
    Nick
  4. megadriveguy
    19 May 2010
  5. drjaydee
    1 Sep 2009
    we're with be broadband, its ADSL
  6. drjaydee
    1 Sep 2009
    are the wireless dual band? because i heard that if a wireless-g attaches to some routers, all transfer speeds are limited to g-speeds. don't know if this is true or not :/
    is there a massive difference in them? other than one having gigabit ethernet?
    would it be better to connect the main PC to the router by wireless, or will the transfer speed change depending on whats connected?
    e.g. 300mbps wireless, 2 computers trying to connect to main 300/3=100mbps?
    100mbps wired = constant 100mbps?
    is this roughly how it works?
  7. megadriveguy
    19 May 2010
    100mbps wired = constant 100mbps? yes
    Wireless = crap
    Lets clarify, wireless is **** don't use it unless you have to, the connections are unreliable and your latency increases massively, especially in your case where your looking to have loads of stuff connected at once
    if you don't have to use it don't
    Can you put the PS3, 360, Pc's on Ethernet and keep your wireless clear for your laptops
    Gigabit switch's are are cheap as is Ethernet cable
    http://www.amazon.co.uk/8-Port-Unma...1_7?s=computers&ie=UTF8&qid=1315678242&sr=1-7
    http://www.amazon.co.uk/TP-Link-Gig...1_1?s=computers&ie=UTF8&qid=1315680129&sr=1-1
  8. Bumfluff101
    Bumfluff101 Minimodder
    10 Jan 2010
    Would homeplug adapters be any good for this?
    Sent from Bittech Android app
  9. drjaydee
    1 Sep 2009
    the only things that are close enough to be connected by wires are the main PC and the xbox, which is in the lounge, if i connect the PC and xbox through the gigabit switch, connected to the router, will that get full gigabit over the LAN?
    to clarify:
    Router > Gigabit switch > PC
    ------------------------------> xbox
    ---------> laptops, PS3 etc. (connected wirelessly)
    because the xbox only has a 100mbps connection, will there be a speed boost for rest of the network by using gigabit?
  10. megadriveguy
    19 May 2010
    Nothings really too far away
    http://www.ebay.co.uk/itm/100M-Netw...ssories_SM&hash=item41586c4db8#ht_2713wt_1089
    You only get a benefit from gigabit if both ends have gigabit ports
    Switch
    PC to PS3 1000mbit
    PC to 360 100mbit
    to answer your previous question yes n routers do sometimes slow to g speeds if a g device is connected, dependent on the router I think
    Homeplugs could be useful to you though I've never used them,
    http://www.amazon.co.uk/TP-Link-TL-...1_1?s=computers&ie=UTF8&qid=1315683985&sr=1-1
  11. megadriveguy
    19 May 2010
    Also what are you streaming quality wise 720p or 1080p and what size of video files, i guess your using something like PS3 Media server
  12. drjaydee
    1 Sep 2009
    didn't really want to go the homeplug route, wanted a more 'standard' network set-up, also didn't want the costs associated.
    it's a mixture of 720p and 1080p stuff, using PS3 media server
    the main priority is the xbox, as its in the living room, if it were wired in, would it be fast enough to watch 1080p content? as the xbox only has 100mbit lan, is the advantage of gigabit only if there is more than one device added?
    e.g. one 100mbit deviced attached to gigabit swich, accessing gigabit PC = transfer ~100mbit
    if two 100mbit devices were attached to a gigabit switch, accessing a PC attached with 1gbit, would both devices be able to access at ~100mbit?
    sorry for lack of knowledge, but setting up networks is pretty new to me
  13. drjaydee
    1 Sep 2009
    shameless self bump
  14. megadriveguy
    19 May 2010
    If you want to do it on the cheap just buy one of these
    http://www.amazon.co.uk/exec/obidos/ASIN/B0031SUB4S/ref=ox_ya_os_product
    There pretty solid routers and there cheap you would see a improvement over your g router
    No point in a switch if your not going to bother laying Ethernet everywhere
    just plug your 360 and pc into the 100mbit ports on the back and you should be fine
    if you use the PS3 a lot try to get that on 100mbit Ethernet port as well
    Your not spending much and it should suffice unless your talking massive files 20GB files for instance if your talking 4 5 GB you should be ok
  15. donok
    donok Every Little Helps .....
    16 Feb 2011
    Cheapest way to deal with this would be to invest In some Ethernet cable and hide it under carpets etc to get to the devices that need it. If your modem outputs at a
    Gigabit then get a £20 switch and drop all the devices on to it.
    I was lucky enough to buy a house that had already been wired up.
    I have virgin 50meg broadband with a superhub that outputs at a gigabit and does wireless.
    So in my place it goes
    Modem (superhub) ---- switch ----- Wireless modem downstairs, ps3, computers
  16. drjaydee
    1 Sep 2009
    i think this is the way i'm going to go, if i bought a large reel of ethernet cable, how do you attach the plugs onto each end? is a special tool required? or can it be done by hand?
  17. Parge
    16 Jul 2010
    To be honest, I use a wireless N router to stream 720p content and its absolutely flawless.
  18. drjaydee
    1 Sep 2009
    how does it cope with multiple devices streaming content? because that's what's causing the main problem.
  19. jizwizard
    jizwizard Modder
    24 Dec 2010
  20. drjaydee
    1 Sep 2009
    how easy of a job is it? i'm relatively handy, just not done it before
