Build Advice Streaming PC - Mixer.com
Discussion in 'Hardware' started by Neoki, 30 Sep 2017.
  1. Neoki
    Neoki Minimodder
    26 Oct 2004
    Heya all, I am looking to build a new rig for streaming on mixer.com
    I currently use a laptop with corei5-5200u and can only run obs and two other programs.
    The quality is terrible.
    What do you recommend, people have been saying ryzen is good for Multitasking
  2. theshadow2001
    3 May 2012
    I don't know much about streaming requirements but there is this:
    You could go with a Ryzen based system with software encoding. Depending on what you consider good enough in terms performance/quality an i7 and the same software encoding might also be more appealing as I believe it will be cheaper.
  3. silk186
    silk186 Derp
    1 Dec 2014
    I second Ryzen, more cores will become increasingly important in the near future.
    Also, AMD doesn't come out with a new platform once or twice a year.
  4. Guest-16
    Guest-16 Guest
    What's your budget?
  5. Neoki
    Neoki Minimodder
    26 Oct 2004
    Probably about £1000
