Overclocking Stuck on i5 750 overclocking, help.
Discussion in 'Hardware' started by Synay, 28 Mar 2010.
  1. Synay
    Synay What's a Dremel?
    25 Oct 2009
    So I got myself EVGA P55 ForTheWin board and brand new i5 750. Being me standard is never enough so I started to clock up. Went to 4GHz no problem (have Corsair H50 on it) and now I'm stuck - every increase I make locks up my computer. Here is how my pc is configured now:
    Vcore: 1.425V
    CPU PLL: 1.3V
    At those setting it's rock solid with temperature never raising above 72 degrees, but do you have any ideas on how can I push it forward?
    I mean don't get me wrong, at those speeds it's a monster, but still, wouldn't be myself if I wouldn't try to push it as far as I can.
  2. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    would be better if you posted somthing like this:
    Ai Overclock Tuner - Manual
    CPU Ratio Setting - Auto
    Intel (R) SpeedStep (TM) Tech - Disabled
    Intel (R) Turbo Mode Tech - Disabled
    BCLK Frequency - 200
    PCIE Fequency - 100
    DRAM Frequency - DDR3 - 1600MHz
    DRAM CAS# Latency - 8 DRAM Clock
    DRAM RAS# to CAS# Delay - 8 DRAM Clock
    DRAM RAS# PRE Time - 8 DRAM Clock
    DRAM RAS# ACT Time - 24 DRAM Clock
    CPU Voltage - 1.32500v
    CPU PLL Voltage - Auto
    QPI/DRAM Core Voltage - 1.25v
    IOH Voltage - Auto
    IOH PCIE Voltage - Auto
    ICH Voltage - Auto
    ICH Voltage - Auto
    DRAM Bus Voltage - 1.64v
    DRAM DATA REF Voltage on CHA - Auto
    DRAM CTRL REF Voltage on CHA - Auto
    DRAM DATA REF Voltage on CHB - Auto
    DRAM CTRL REF Voltage on CHB - Auto
    DRAM DATA REF Voltage on CHC - Auto
    DRAM CTRL REF Voltage on CHC - Auto
    Load-Line Calibration - Enabled
    CPU Differential Amplitude - Auto
    CPU Clock Skew - Auto
    CPU Spread Spectrum - Auto
    IOH Clock Skew - Auto
    PCIE Spread Spectrum - Auto
    Thats from my 4Ghz OC a few weeks back, your BIOS will look different so change it as you see fit, but it just gives us a good idea where you are on the settings you are using. highlight what you changed in red also if you would.
    Pro Tip: never go above 1.5coreV unless you have nitrogen at hand.
  3. Guest-16
    Guest-16 Guest
    Don't raise the CPU voltage any more. 72 is quite toasty already.
    Try the QPI/VTT not the PLL. Over 200MHz may require 1.35-1.4/1.45V depending on the board but very high is not good for the cpu in the long term.
    Tbh, isn't 4GHz fast enough? :p
  4. Synay
    25 Oct 2009
    Thanks. I believe 4GHz is enough for everything I do but one thing: Folding. So I'm trying to get as much out of the CPU as I can. I'm getting some sweet points now, but you know how it is, more is always better :)
    Later on today I'll get to BIOS and write down all the specifics and post here. Thanks guys.
    PS. I just noticed my fan wasn't running full speed (I have Scythe Gentle Typhoon on my Corsair) so I upped it to 1450RPM and saw a temperature drop to much nicer 68 degrees.
  5. rollo
    rollo Modder
    16 May 2008
    want a faster cpu buy one in the end of the day
    your pushing that 750 to its max as it is. 4ghz at 1.42v isnt good for the chip long term. I rarely go over 1.3v when overclocking. i always find anything above that and your in danger of damaging the chip.
    68c isnt that much better than 72. Id personally drop it down to 3.6ghz and lower the voltages you will notice the performance drop off isnt huge. i930 is the way forward for faster than 4ghz overclocks.
  6. Big Elf
    23 Apr 2009
    I'm puzzled why 72ºC is considered 'toasty'? I'm sure I've read reviews of systems in Custom PC that have temperatures 10-15ºC higher than that without comment.
  7. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    I believe it's the temperature specification listed by intel. I imagine they don't take a spec like that lightly so it's probably 72c for a reason.
  8. Otis1337
    28 Nov 2007
    prime gets my i7 to 80c at 4Ghz which is fine, because nothing that i would do day to day would push it past 40%
  9. Synay
    25 Oct 2009
    Well, yes, but I do run Folding@home on it every day, for at least 18 hours a day. So it gets stressed 100% almost all the time. Do you guys think I should build a proper watercooling system here? Would it be any help/difference with temps and overclocking? I never done anything with watercooling before apart from this Corsair H50 I'm running now.
  10. Big Elf
    23 Apr 2009
    Intel quote a lot of specs that are ignored like vcore and QPI voltages. Example - Intel told me they recommend a QPI of 1.15v and anything over that is considered out of spec.
    Synay - TBH I wouldn't bother with laying out extra cash for maybe a 200MHz increase if you're lucky with possibly around 10ºC decrease in temps. You'd also have to factor in the annual/biannual maintenance as well.
  11. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    LOL, my iy 920 hits 85 degrees c on stock speeds, at load. :D 52 degrees c at idle.
  12. rollo
    rollo Modder
    16 May 2008
    lol greg vendor the stock cooler and use sumit decent. Water cooling would get it down to some resonable temps
    72c is high in long term usage. And if you run folding your cpu is always capped at near enough 100% so your running prime95 18hrs a day as a comparison for the rest of its life. Eventually you will hit the point were it will collapse.
    my brothers i750 is running at 4ghz at 52c at 100% load using water cooling.
  13. Synay
    25 Oct 2009
    I just lowered the Vcore to 1.4125V and it still seems very stable. As a bonus the CPU's temperature dropped to more rescpectable 58 degrees. Now I can see that Vcore was never a problem, will try with VTT as Bindi said. For now my config is as follows:
    Multiplier: 20
    CPU frequency: 200
    PCIE frequency: 100
    QPI frequency: 4800GT/s
    MCH strap: 1600Mhz
    Vdroop: Enabled
    Vcore: 1.4125V
    CPU PLL: 1.9V
    Everything is left as either default or auto.
    Any suggestions where can I improve? As Big Elf said - no point on spendin extra cash now. Will try to get as much as I can from what I have.
  14. Big Elf
    23 Apr 2009
    I'm only familiar with overclocking a Core i7 but if it works in a similar way then reduce the RAM frequency as low as it will go. You should be able to reduce the VTT and also it's likely you could reduce the vcore as well. 1.41v seems high for 4GHz.
  15. rollo
    rollo Modder
    16 May 2008
    leave as is and be happy 58c is a decent result well done
  16. Rat1sully
    Rat1sully At Least Skt478 Never Broke
    29 Apr 2009
    mine hits 55-60 at only 3.8GHz and thats with a fenrir and an antec1200 so i'd be happy with it tbh
  17. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    58c is really good for 4GHz. In comparison, my 920 with stock voltages - although I suspect the Rampage overvolts anyway,runs alot hotter at 67c with ht on. I'm actually going to revamp the system in a couple of months with the usual TJ07 + quad radiator idea. I'd say it was the next step in getting higher frequencies.
