A/V Studio Monitors with xbox one and PC?
Discussion in 'Tech Support' started by krazykid035, 7 Apr 2014.
  1. krazykid035
    krazykid035 Entrepreneur
    13 May 2009
    I bought an xbox one recently and want to have the sound play through my studio monitors (jbl lsr308) through my sound card (ASUS Xonar Essence ST).
    Not quite sure how to go about this:
    Speaker Inputs (per speaker): 1 x XLR, 1 x TRS Balanced
    xbox one outputs: hdmi, optical
    Sound card
    Line In: Yes
    Line Out: Front R / Front L, Headphone out
    SPDIF Out: High-bandwidth Coaxial/TOS-Link combo port
    MIC In: Yes
  2. jinq-sea
    15 Oct 2012
    Just wondering - why do you want to run via your sound card? Wouldn't it be easier just to go direct into the monitors?
    You'd probably be best trying to locate a cheap optical -> RCA converter (I know CYP make them, like this, and then just going from RCA to 6.5mm jack (unbalanced).
    Of course - you can go all out and get a balanced out DAC, but that depends on budget :)
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Perhaps you might find a cheap little receiver which you can use as an input switcher and preamp.
    Otherwise I suppose the easiest/cheapest solution would to buy a basic dac with optical in and rca out. Plug the analogue out to your soundcard line in and place it in listen mode.
  4. krazykid035
    13 May 2009
    Wouldn't the sound quality be much better through the card?
  5. krazykid035
    13 May 2009
    I do have a receiver I can use. I think it is fairly recent with hdmi, optical, etc but it uses speaker wire and not the plugs.
  6. IvanIvanovich
    31 Aug 2008
    Buy a spare cable and hack the end off of it so you can use it on terminals?
  7. jinq-sea
    15 Oct 2012
    No dice here, as the monitors are active.
    Does the receiver have pre-outs? If it does, there's your winner. XBOX -> HDMI -> Receiver -> Pre-out L&R -> RCA -> Unbalanced 6.5mm jack -> monitors
    In answer to your other question, running through the sound card is a bit redundant in terms of improving sound quality, to my mind.
