Education Studying! That's hard.
Discussion in 'General' started by ComputerKing, 30 Aug 2007.
  1. ComputerKing
    8 Sep 2006
    mm Force myself, I think this is the best I can do, You are right my friends. Thanks Fod for the advice :D
    But now I keep study for too long horus or like 30min then break then 30min then break etc. ?
    mm It's the most important years in my life, Like you guys said, study hard get kickass job ;) and top hardware.
    cpemma That link is amazing, I like it and I will print it and keep read it many times, Thanks very much
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    You'll find that you're better at working, the closer it is to the deadline. :)
    At the moment, I've got loads of work to do, but its ages until the deadline. You have to have some self-control, but it does help to seperate, in your mind, where you work and where you play. I work on my old laptop, I play on my PC and my Wii.
    I do procrastinate a little bit, but it's much better than it might otherwise be.
  3. ComputerKing
    8 Sep 2006
    That's right but the thing that I don't play on my PC,
    I just eat the time or lose it With that because I feel boring to study or something.
    It's kinda I must study everday because I have alot of lessons every day need to be understood well! and I Don't do that and now 2 weeks gone from school.
    Thanks.
  4. DougEdey
    5 Jul 2005
    If studying was easy there would be no job competition
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I find it's a challenge to get started more than actually studying.
  6. ComputerKing
    8 Sep 2006
    Ramble Yes That's Right! It's very very hard challenge! :worried:
    DougEdey That's Right too, Yeah ;)
    My Dream is Join American Universty so it neeeds high marks :(
  7. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    What I used to do is take my power cable away and sit on it for a bit to stop me using the PC. When I did need to PC to work then i'd create a brand new account on the Pc which was denied internet access and had no files on except for Office. No MP3s, no nothing.
    Then I got a DS lite though, so nothing really helped.
  8. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    I exercised what is commonly known as self-control.
  9. ComputerKing
    8 Sep 2006
    Yeah the fix is Self-Control. This will need alot of hard work and challenges. I don't know but yes, nothing easy in the life :) I will try this.
    Thanks very much.
  10. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Perhaps you should try studying instead of looking on the internet for ways to study.
  11. Nexxo
    23 Oct 2001
    I'm with Moriquendi on this:
    Having said that, concentration is a balancing act of the brain. You often find that you can concentrate better on studying/reading (mainly a left-hemisphere activity) when you give the right hemisphere the brain something to do to prevent it from distracting you from that process (for the record, this left hemi and right hemi model is an oversimplification, but it will do for now).
    The right hemisphere task needs to be relatively undemanding and does not distract the left hemisphere. Basically, put on some music. Not loud, and not your favorite stuff; just some neutral background music. Classical works well.
    Make a time table of study times and what subjects you study. Switch off the mobile, make sure you don't get interrupted. Make sure you are comfortable.
    Study for 30 minutes. After that, your concentration slacks. Take a ten minute break: have a cup of tea, ponder what you've just read. Write down what you learned in the last 30 minutes in one sentence. Allow your working memory to store the information --it will take that 10 minutes to do that. Use a timer to time the work and break periods.
    Make a mind-map to integrate what you know on a subject:
    - take a big piece of paper. Write the subject in the middle.
    - Write all you know about the subject around it, in short titles/headings.
    - Draw lines between the titles/headings that are associated with each other. Now your mind gets an overview on how to organise the information you are learning, and you also spot what you need to learn more about.
    Pace yourself- study no more than 6 hours a day if possible. Get some physical exercise in, because that improves energy. Eat and sleep well --sleep is when your memory sorts out all the information you have learned that day: if you don't sleep well, you won't retain well. Set yourself a reward at the end of the day.
    And don't buy a Nintendo DS. Or Bioshock. :p
  12. ComputerKing
    8 Sep 2006
    WOW! Nexxo MY brother you should work on advice people place or some thing! WOW! this is really what I need and easy to do, You can feel me and my mind! This is awsome! Thanks very much. I will start from what you said and do it now. That's what I was need really.
    Thanks Thanks my Daddy Nexxon :)
  13. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I've always felt music distracts me, and I do listen to classical.
    What I do is try and get rid of all sound distractions, make myselfa cup of tea and then just get stuck into an exam paper. My concentration never wavers until I'm finished.
  14. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Only one other tip, get up early, do a period of studying in the morning then take a break for an hour or two, eat lunch outside or go for a walk then get back at it for the afternoon and do the same at tea time. If you let yourself sleep all morning you will still feel tired in the afternoon and wont be able to concentrate, getting outside really helps with this too, it helps you feel refreshed.
    Moriquendi
  15. Guest-23315
    Guest-23315 Guest
    When I'm working at school, I just turn off my screen and speakers and just concentrate on what I'm doing. Just make sure you don't do too much at a time. 50 mins of work and then a 10 min break seems to work perfectally for me.
  16. pranks7er
    pranks7er mange tout
    25 Dec 2002
    get some one to change ur login in password and not tell you until exams over or hide your keyboard and mouse somewere were its real awkward to get to eg someone elses house
  17. Firehed
    15 Feb 2004
    Honestly, for me it's just a matter of practice and self-control. When deadlines are approaching, I'm much better at it. That recent blog post that someone linked to (cthippo perhaps? I'm too lazy to check the first page) is a good resource. Setting a goal is a major step - know what you want to get out of it. When I had to study for a stats exam, I knew we were allowed to bring in a formula sheet with us. So my goal was to make a very readable and useful formula sheet. Once I knew what I wanted and knew when I needed to have it done by (the next day, of course), it was fairly easy - I had to just sit down and pound it out, and tell myself that I wouldn't do anything but that until I was finished. And I did. It was a fairly painful process and I certainly had to take a couple short breaks during the time, but it made the difference between passing with a fairly decent grade and failing miserably.
    Having someone hide your power cord won't help, because if it's not the computer then you'll just find something else to distract yourself with.
  18. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    Uh, yeah Daddy Nexxo, you should really consider a career where you use your insight into how people work to help them. I bet you'd be good at it. :D Maybe you could take a few classes on how the brain works and work that into the mix, too. Then you can feel more people and their minds! Nexxo the Mind Feeler. I has a ring to it.
    CK, your posts liven my day in the strangest ways and I thank you for it.
  19. Nexxo
    23 Oct 2001
    That just sounds... wrong, somehow. :worried:
    Seconded. :)
  20. ComputerKing
    8 Sep 2006
    LOL! No Problem I thank you guys that you helped me to do that, Every one here keep push me :D
    Yeah self-control, It worked with me on the last 6 hours with 1 hour break I think ;) I studyed a good study first time on my life ;) yeah Trun off the PC and study ;) This is the best way.
    Thanks alot, I think I did it for 1 day, I hope I keep on doing it for this year ;) Thanks too much.
